Old 12-31-2006, 09:15 PM   #1
mrjs80
why...ground straps
Why did the factory use uninsulated ground straps vs regular insulated wire? Should I order new straps or can I just use wire? If I need the straps which vendor sells them.
mrjs80 is offline   Reply With Quote
Old 12-31-2006, 09:25 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: why...ground straps
The ground straps are no danger if they touch anything, so they do not require insulation. I would use braided ground straps vs regular wire. I am not sure who has them.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 12-31-2006, 09:41 PM   #3
mrjs80
Well if I can I would rather use wire since I have a roll of 2 gauge and tons of ring terminals. No money spent. I know there is no danger with it not being insulated but I think they look like crap and don't see why they would be any better than regular wire. I'm doing a frame off and don't really have any of the old ones left.
Old 12-31-2006, 09:45 PM   #4
centsless
centsless's Avatar
If you are using 2 GA then it will handle more than any braided will. Go ahead and use it, I say. Especially since its FREE!!!!!
2003 Suburban
1981 Corvette
Old 12-31-2006, 10:57 PM   #5
Hart_Rod
Hart_Rod's Avatar
NAPA and most parts stores sell the factory or "universal" grounding straps.
Hart_Rod is offline   Reply With Quote
Old 12-31-2006, 11:20 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I don't think it makes any difference which you use so long as it's grounded.The most overlooked part of auto wiring is grounding.Without good grounds some of the electrical is prone to problems.Also good grounds keep the system from grounding back through other components which could cause shorts and possibly fire.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-31-2006, 11:35 PM   #7
mrjs80
Thanks for the replies. I didn't think there would be a problem but then again why do they make specific "ground straps" then?
Old 12-31-2006, 11:49 PM   #8
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Maybe it lasts longer due to its flexibility....could be wrong. Atheys classics sells them.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Thread Tools
Display Modes
