Old 01-03-2007, 10:51 AM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Question 78 3/4 ton Master Cylinder and Proportioning valve question
I have removed a manual brake master from my 1970 K5 and have installed a master cylinder, booster and proportioning valve from a 1978 3/4 ton.
I removed the donor parts quite some time ago and I don't recall which reservior is supposed to feed the front as opposed to the rear.
I currently have it hooked up with the front reservoir going to the proportioning valve to feed the front brake lines.
Can someone with a 78'ish 3/4 ton take a look and see which reservoir feeds your front brakes? I believe your proportioning valve should be on a crossmember about below the engine fan.
Here is how mine is presently ran
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Thread Tools
Display Modes
