01-09-2007, 05:24 PM | #1 |
14 bolt gov locker
Is there anyway to modify a gov locker in a 14bolt ff axle to operate like any other locker.
Thanks Mark
THERE is NO REPLACEMENT FOR DISPLACEMENT 1971 CHEVY 4X4 4SPD 406 CHEVY Lockers front and back 1978 BONNEVILLE 403 OLDS 1985 K1500 F5L912 Deutz Power (work in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=389561 1963 Oliver 1600 diesel 1956 Oliver Super 88 |
01-09-2007, 06:26 PM | #2 |
Re: 14 bolt gov locker
Umm, not that I know of. Get and open carrier and get a Detroit.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-09-2007, 07:49 PM | #3 |
Get a mini-spool...its less than half the cost of a Detroit. Not only that, a Detroit locks up so fast anyway it chirps on street corners. I'm a truck puller, and have heard of Detroits blowing up...but, never a spool.
01-09-2007, 10:53 PM | #4 |
River life......
One of the lunch box lockers fit in the gov carrier, quick lok may be the name of it.
01-10-2007, 12:04 AM | #5 |
K5Camper
I havent heard of a lunch box locker that fits in a gov lock carrier. Then again, the detroit locker for a 14b looks a heck of a lot like any other lunch box locker since it replaces the spider gears on an open carrier.
Run the gov bomb until it blows and have an open carrier/detroit waiting to install.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
01-10-2007, 03:38 AM | #6 |
to answer your original question, you can weld it up so it acts like a locker
at my old job, had a fragged 14 bolt gov lock under a C30 dump truck. when it went, the carrier was so scarred i dont know if i would want to use it again. the dealership didnt reuse it when they re did the axle, but of course they dont make any $$$ by reusing the old. i would just echo to find an open carrier and use your insert of choice (detroit, lock right, mini spool).
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
01-10-2007, 11:29 AM | #7 |
[QUOTE=1969 GMC;1979040i would just echo to find an open carrier and use your insert of choice (detroit, lock right, mini spool).[/QUOTE]
Any leads on where to find those products? I've also got one of these that needs over-hauled. - THX
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
01-10-2007, 12:45 PM | #8 |
I think the problem is with a lunch boxs locker going into a 14b ff gov lock carrier is the that the gov lock has 3 spider gears as compared to a open carrier with 4 spider gears.
The clutch plates don't look bad but they don't last as long a regular locker. This is a rear axle for my bothers truck he's converting to a 3/4. The gears are 3.73. Will all the other 14bolt carriers cross to it or does he need a 3.73 carrier. If he does i guess he not out much he only paid $50 for the axle anyway. Another question is my truck 71 chevy 1/2 ton 4x4 has a factory locker (i think) in the rear. What type of locker is that. It chatters when i turn and it never lets just one wheel spin even it its up in the air. Both wheels spin when i have the rear off the ground, and i cant hold one and spin the other one. Thanks Mark
01-10-2007, 06:31 PM | #9 |
Post Whore
The 71's locker should be a No-Spin which is a Detroit Locker.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
01-11-2007, 03:04 AM | #10 |
Mark, I would normally agree except he said half ton. That means a 12 bolt and some sort of posi, not a true locker. I am not too familiar with posis, but I *think* those can be rebuilt with new clutch packs.
01-11-2007, 10:53 AM | #11 |
My rear axle is a 12 bolt but i am sure that its a locker by how it acts, but i could be wrong. Both of my cars have posi rear axles and i can jack up one wheel and spin it by hand, but on pavement they will leave two black marks from the start. The pick up i cant spin the wheel it i jack it up in the air. the only way is to jack up both back wheels.
01-11-2007, 02:30 PM | #12 | |
01-11-2007, 03:23 PM | #13 |
Post Whore
Gotcha, I was stuck in the 3/4 ton mindset.
Thread Tools | |
Display Modes | |
