Old 08-23-2002, 07:17 PM   #1
Old Paint
Question Nylon timing gear
Anyone know if a `72 350 engine has the nylon timing gear? The 72 I had with a 307 had the nylon gear and it flew apart at about 160,000 miles. I have about 145 thou. on this motor and I`m wondering if I should be thinking abouy changing the chain and gears. THANKS
Old Paint is offline   Reply With Quote
Old 08-23-2002, 07:48 PM   #2
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Shotgun it. If it ain't noisy, it's probably nylon and getting ready to go south. Even if the gear is still good, the chain probably needs a rest.
I think you have to pull the front edge of the oil pan down to remove the timing cover, so it won't be quite as much fun as it could be...
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 08-23-2002, 08:58 PM   #3
speeddemon
speeddemon's Avatar
If you have 145k on the engine yse I would replace the timming chane. You can pick up a double roller chain pretty cheapand you will not have to worry about the oil pump locking up from the nylon chain.
69-C10 LWB
71- fleetside shortbed
It's a shame stupidity isn't painful
Never play leapfrog with a unicorn
speeddemon is offline   Reply With Quote
Old 08-23-2002, 08:59 PM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
Do it. Hell, the nylon gear on my '70 let go at 90k or so.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 08-23-2002, 09:05 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've seen them go at 60K, I recomend tossing it.
Old 08-24-2002, 05:22 AM   #6
Hooter
My other Love
Hooter's Avatar
Some chevy gears that ive dealt with were just coated in nylon while other were nylon. Or in the case of my 77 chevy the 400 had steel gears (i was the first person to change the timing set). I would recommend changing it every 100 000 miles but i am also cheap and sometimes lazy
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 08-24-2002, 11:36 AM   #7
Old Paint
nylon gear
Thanks guys you talked me into it. When mine let go in the old 307 it bent some push rods and turned into a real job.I guess this is a case where you should fix something that isn`t broken...(yet). THANKS
Thread Tools
Display Modes
