Old 01-20-2007, 07:36 PM   #1
Frizzle Fry
Frizzle Fry's Avatar
476 Install Pictures
I put a new cam, lifters, intake, and carb on the 396 and the bottom end couldn't hang with the new-found power...
Crazy thing is that it still ran with the piston like that!
I know, I know... don't bolt nice parts on a tired bottom end...
So I built the 476 from a freshly machined block (454 +0.100" bore). Bought the assembled shortblock and heads, and slapped it together with the existing bolt-ons. I had to buy another new cam and lifter set though bc the comp lost a lobe in the process.
It's very healthy but I have yet to really get on it because it's still breaking in. After I change the oil this weekend and get some dry roads we'll see what she's got...
Frizzle Fry is offline   Reply With Quote
Old 01-20-2007, 07:38 PM   #2
Frizzle Fry
Re: 476 Install Pictures
Here's what the engine bay used to look like
and you can see the destroyed piston prior to removal here
Old 01-20-2007, 07:38 PM   #3
kenm78
Broken Down
kenm78's Avatar
Ouch Im glad my wasn't that bad
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 01-20-2007, 07:41 PM   #4
Frizzle Fry
out with the pig... (she made quite a mess mess)
Old 01-20-2007, 07:44 PM   #5
Frizzle Fry
Painting the new block
Old 01-20-2007, 07:48 PM   #6
Frizzle Fry
Heads on
it had studs for a windage tray so I had to get one... (note the small block mounts I used thanks to a FAQ from this board)
Old 01-20-2007, 07:48 PM   #7
redhead69
fugedaboutit
redhead69's Avatar
Currently truckless
redhead69 is offline   Reply With Quote
Old 01-20-2007, 07:51 PM   #8
Frizzle Fry
etching primer after hours of cleaning
Painted (the inner fenders can be done later)
Old 01-20-2007, 07:52 PM   #9
redhead69
fugedaboutit
redhead69's Avatar
Currently truckless
Old 01-20-2007, 07:56 PM   #10
Frizzle Fry
New combo goin in with the help of some expensive labor (476/TH400):
Old 01-20-2007, 07:59 PM   #11
Frizzle Fry
I removed the wire guide on the firewall and re-routed the wires to clean things up. I also took this oppertunity to finally run the proper 12 AWG wire to the HEI.
Old 01-20-2007, 08:01 PM   #12
Frizzle Fry
few more parts...
Old 01-20-2007, 08:04 PM   #13
Frizzle Fry
When I fired it up for the first time I had a heater core leak! So I figured it was a better time than any to replace it. What a pain that is! While it was out I had no choice but to paint the heater box... You can see the Accel billet HEI, painted brake booster, and new/painted MC here too:
Old 01-20-2007, 08:13 PM   #14
Frizzle Fry
Here's all the specs and some final shots for now:
* 476 (454 + 0.100 for 4.35)
* Heads: 336781 oval, 118cc chamber, 256/114cc port
* Pistons: Speedpro -10.5cc dome with above heads makes 9.5/1
* Intake: Edelbrock Airgap
* Carb: Edelbrock 1411 750cfm
* Headers: 1 3/4" primary 3" collector full length neck down to 2.5" post collectors through dual flowmaster 40 series. No H or X yet.
* Cam: Lunati Voodoo Here's the link to my cam specs: http://store.summitracing.com/partde...0&autoview=sku
* Accel HEI with "supercoil"
and I have full roller rockers to go in when I have the time (they were delayed in shipping so they didn't make the build)
Old 01-20-2007, 08:26 PM   #15
JAKES 68GMC
Aluminum slot wheels rule...
Wicked! That Burb is gonna be a true sleeper!
JAKES 68GMC is offline   Reply With Quote
Old 01-20-2007, 08:52 PM   #16
65-72 chevytoys
65-72 chevytoys's Avatar
That is awesome, thanks for all the pics and details! Quick question did you disassemble the A arms and steering linkages and what did you use to paint the frame? Did you sandblast it or just degrease and paint over rust?
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 01-20-2007, 09:41 PM   #17
Frizzle Fry
Thanks. I cleaned it with carb cleaner and a wire-wheel/brush down to bare metal for the most part. I painted just the area you see in the pics. No rust though. The 1/2" of oily muck must have been good protection.
Old 01-20-2007, 10:00 PM   #18
Yukon Jack
Post Whore
Yukon Jack's Avatar
Looking great - sounds like a stout engine! I haven't read your 61 Stepside build thread in a while so I'm gonna jump over there - if any of you haven't checked out that thread - you really need to!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-20-2007, 10:09 PM   #19
Bob Moore
Great job. What brand/part # are the headers?
TIA - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-20-2007, 10:15 PM   #20
72cheyennesuper20
72cheyennesuper20's Avatar
Looks like a clean install (should get it also), Digging the polished s200's on Burb
72cheyennesuper20 is offline   Reply With Quote
Old 01-20-2007, 10:29 PM   #21
wheels67
wheels67's Avatar
Thats cool, you got little helpers in the garage too!!
Motivating thread.
wheels67 is offline   Reply With Quote
Old 01-21-2007, 12:49 AM   #22
FarmTruk
In Memoriam...
FarmTruk's Avatar
She looks minty fresh now...
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-21-2007, 08:23 AM   #23
70GMCer
70GMCer's Avatar
Looks great!! Although I see someone was sitting down on the job in the back ground.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-21-2007, 09:04 AM   #24
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Nice Burb!
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 01-21-2007, 09:48 AM   #25
Hart_Rod
Hart_Rod's Avatar
Glad you got it back on the road Mike. Now get busy with that 61!
Hart_Rod is offline   Reply With Quote
Thread Tools
Display Modes
