04-24-2002, 10:00 PM | #1 |
dragging mufflers
I,ve got a problem see they decided to put this speed bump in my court that is I swear 8 inches tall and my high $$ flowmasters are dragging. Ive got a 4/6 drop and going to raise it 1 inch all around but I was wondering how you could run the mufflers with plenty of ground clerance. I'm running manifolds not headers and they dump in front of the axle. suggestions please
------------------ 1970 shortbed(project) 350/350 dropped 4/6 21/2" flowmasters.Plans for bigblock or just a little stroker.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
04-24-2002, 10:14 PM | #2 |
try layin em flat if they arent already
------------------ 72 chevy lwb 350 lunati cam ported and polished cast 2.02 heads proform hei edelbrock performer rpm and 750 carb balanced bottom end 9.5:1 compression ps,pb th350 with a tci 2500 stall convertor full man v-body kevlar clutches and bands as well as other goodies
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
04-24-2002, 10:17 PM | #3 |
They are flat but they are 3" thick plus 1/2" clearance between frame.
04-25-2002, 12:11 AM | #4 |
flowmaster just came out with a new series that are thinner for vehicles that have clearance problems. ill be selling mine to get these.
------------------ 68 swb fleet soon to be bagged and big block powered 68 lwb fleet in primer 35 chevy truck 97 dodge on 35 boggers 3 out of 4 aint bad! Jefferson city, MO |
04-25-2002, 07:01 AM | #5 |
how much for yours??? i have mine up under the box in front of the rear but mine exit at the rear bumper.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
04-25-2002, 10:42 AM | #6 |
aka Crusher, Crushergmc
There is a company that make thin mufflers for hotrods. Try doing a search on "thin mufflers" , or maybe "hotrod mufflers"
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
04-25-2002, 10:49 AM | #7 |
04-25-2002, 11:24 AM | #8 |
Check this link and look under the 68 restoration link.
They have cut holes into crossmember which have the trailing arms and carrier bearing attached to it. They have also made some other nice mods on the rodstoration of this clean early truck. I was considering this mod while I had mine apart but since it will ride at stock height I am not sure whether there would be a benefit from this or the one piece shaft mod. When it comes time for mufflers you can be sure that whoever installs them will route them correctly instead of bending the sheet metal on the back of the cab. Both of my trucks have had this done during their lives. http://www.earlyclassic.com/ ------------------ John Hutchison Grapevine,Texas 76051 71 1/2 ton swb 307 pg 69 Jaguar XK-E 4.2 Roadster
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
Thread Tools | |
Display Modes | |
