04-23-2002, 03:45 PM | #1 |
A few more ? about front drums/disc swap!
OK got all my parts ready for the brake swap I was wondering if I left anything out .
My truck Is a 70 model On the spindles do I need to cut off the spindle stop?I have 72 model spindles And I bought new brake lines the rubber ones do I need to change my hard lines too? |
04-23-2002, 06:54 PM | #2 |
No you don't have to cut anything.If your old brake lines look weather checked bad then replace em
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
04-23-2002, 07:22 PM | #3 |
member #16
With the disc setup the hard lines go to the front of x member. You will have to make the clips and weld or bolt to X member. Also look at your rubber hoses,they use different size tubing on each side. I put 72 spindles on a 70 and had no problem with the steering stops. The easiest way is to get the front lines off of the donor truck.
------------------ 67 SWB 350eng th400 3:07 posi tilt&tach PS/P/Disc Brakes old air a/c P/W keyless entry gaylord lid 70swb project truck 350/th400
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-23-2002, 07:22 PM | #4 |
2nd that,dont cut the steer stops! I used a 71-72 lower a arm on mine, but you can trim the stops on the spindle if you dont have access to replacement arms. Use the ball joints for the year of the spindle,& you will need to change the tierod assys(71 up),& may need to change the center link(also 71 up). Good luck.........69
http://community.webshots.com/user/hotrodhorn |
04-25-2002, 01:41 PM | #5 |
69 Longhorn,
How much did you trim off the spindle stops? I have a 69 and parts off a 71. I don't want to swap lower control arms because mine are not rusty at all. I have a set of 71 lowers but they are slightly pitted so I really hate to use them or the rest of the whole cross member (the rotors and calipers need changed). My plan is to use my 69 crosmember with new ball joints all around, 71 spindles, rotors, calipters, 71 i/o tie rods, sleeves, center link, new pitman arm. Make new lines using the 71 xmem as a guide, 71 Master, booster, & prop. valve. new hoses & brake fluid also. What else do I need? ------------------ Woody '69 Custom-10 Deluxe Short Fleetside,Factory 350cid/TH400,A/C,PS,PB,Carpet Coming soon 700R4, 350 Crate Engine, Pwr Disks... |
04-25-2002, 02:45 PM | #6 |
Woody,I used 71 arms,so no trimming was needed. There are a couple guys on the board that used pre 71 arms,& opted to trim the stops on the spindle,but Im not sure how much. You could turn the wheels lock to lock before you tear down,& get a measure,then just try to trim to get the original measure. Good luck.....69 longhorn.
Thread Tools | |
Display Modes | |
