Old 02-08-2007, 10:04 AM   #1
MR MAGOO
MR MAGOO's Avatar
detent cable adjustment
what is the propper way to set a detent cable? is the slotted end of the cable that attaches to the carb suppose to be able to slide or tighten so it stays in a fixed position?
1972 C-10 SWB 350CI TURBO 350 TRANNY, TILT, POWER WINDOW & BRAKES, TANK UNDER THE BED W/MARKER LIGHT FILLER. 3.08 GEARS, CLASSIC AIR :hit2: :hit2: 4 WHEEL DISK BRAKES
2000 chevy blazer
1990 nissan pick-up
1984 mazda pick-up (son's project truck)
MR MAGOO is offline   Reply With Quote
Old 02-08-2007, 11:57 AM   #2
gyjackson
Re: detent cable adjustment
It needs to slide . The idea is, to adjust it so that at Wide Open Throttle it gets tight and pulls the mechanism inside the trans. You can play with the adjustment to get it to kick down earlier if you like, but that's up to you.
'72 Custom/10 SWB project... converting to 4WD
'67 Camaro rs convertible...waiting in line
'99 Ext. Cab Z-71 190000 miles on orig. trans fluid
'02 Black Z-71 burb..(wife's)
'92 Accord (daughter's)....Who want's my insurance bill?
gyjackson is offline   Reply With Quote
Old 02-08-2007, 12:12 PM   #3
71chevylowrider
71chevylowrider's Avatar
I recently had to do this so it's still fresh inmy mind, I couldn't figure out where the adjustment was, it's kind of hidden on the cable right behind it's mount, have someone sit in the drivers seat, lift up on the tab that unlocks the cable, have the person in the truck slowly push the throttle to the floor, & then pudh the tab back down into it's locked position.
71chevylowrider is offline   Reply With Quote
Thread Tools
Display Modes
