Old 02-08-2007, 01:08 PM   #1
cojnit
Nothing clever
cojnit's Avatar
So I started the disk swap
ON the suburban, the front is now five lug and the rear is six. Any ideas what is the best fix for this? I was thinking I could pull the rear shafts and have them redrilled for five lug maybe at a machine shop of some sort.
Also anyone know what the 5 lug pattern size is? I tried a rim off of a 67 chevelle, and the lugs were just a bit wider than the rim hole pattern. I am guessing this means I have a 5x5 as opposed to a 5x4.something...
Got "the Midas Touch!"
cojnit is offline   Reply With Quote
Old 02-08-2007, 01:26 PM   #2
boraxman
Keepin an eye out
boraxman's Avatar
Re: So I started the disk swap
Yup 5x5 bolt patteren, You coud redrill the axles or swap them out for 5 lug axles.
If you swap them make sure the lenghts are correct.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 02-08-2007, 02:03 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
If the rear is 10 bolt 3.73 gears I would find a newer with 5 bolts axles and better gears.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-08-2007, 05:03 PM   #4
krue
Designated A-hole!
krue's Avatar
What year burb is it? Mid 70's (trucks anyways) the rears were wider (same as 71 up) so that if yours is a 70 you have a chance that you just need to swap some 5 lug axles into the rear and be good to go.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-08-2007, 05:05 PM   #5
BowTieOgre
Where can i find that measurement at Krue...I remember seeing it somewhere but cursory searches have been fruitless.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 02-08-2007, 05:15 PM   #6
krue
Designated A-hole!
krue's Avatar
Gimme a minute to go measure mine.
www.daveramsey.com
Old 02-08-2007, 05:18 PM   #7
krue
Designated A-hole!
krue's Avatar
~58.5" backing plate to backing plate, which means the earlier rears are about 57" backing plate to plate.
www.daveramsey.com
Old 02-08-2007, 05:22 PM   #8
cojnit
Nothing clever
cojnit's Avatar
yeah mine is a 69, so I guess that means 57"
Old 02-08-2007, 06:24 PM   #9
Tycoon4u
Tooloose
Tycoon4u's Avatar
Not necessarily mine is a 68 and 71 axles fit perfectly. Go measure them
A legend in my own mind!!!
website: http://www.persmedequip.com/
'68 c10 (current project)
http://67-72chevytrucks.com/vboard/s...ht=cherry+bomb
'04 silverado (better halfs)
'07 wildcat 27rlwb(for sale) http://67-72chevytrucks.com/vboard/c...llinois&cat=17
Tycoon4u is offline   Reply With Quote
Old 02-09-2007, 02:24 AM   #10
cojnit
Nothing clever
cojnit's Avatar
New problem. I removed the drum spindles and the rest of the stuff. when I went to fit the disk spindle on I found that the ball joints didnt fit. I figured it was a disk/drum discrepency.
So I go pick up a set of ball joints that are supposed to be for the right era disk set-up... get the otherones drilled out, install the new ones and nothing. they dont fit either. Now supposedly this set up was off of one of these trucks (67-72). I am starting to think not.
Is there a simple way to tell? maybe it is off of a 73 era.
otherwise is there some conversion to be done?
Also I am thinking I can just change the rotors on the disks to be 6 lug, cant I?
Thread Tools
Display Modes
