Old 02-11-2007, 12:30 PM   #1
67Mach1
67Mach1's Avatar
Wiring diagram for Suburban 70 GMC
I am in need of a wiring harness diagram for a 70 GMC SUBURBAN.
I need to figure out what is causing my tail lights not to function as well as my hazard lights.
Just replaced all lamps, checked connectios at tail lights for continuity, replaced headlight switch.
wanting to disconnect the rear wiring harness and see if the issue is in that section of wiring or if it exsists somewher else.
PS: does anything to do with the tail lights go into the colume? I did some colume work a few weeks ago along with some other under dash stuff which is when this junk started.
Thanks,
Thomas
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 02-11-2007, 01:18 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Wiring diagram for Suburban 70 GMC
I don't think the harness would be too different from a truck's. Click the Index link in my sig and you'll find links to color wiring diagrams. Don't forget to check for good grounds.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-11-2007, 01:35 PM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation Re: Wiring diagram for Suburban 70 GMC
Yes everything that has to do with the taillights goes through the column. More than likely the problem is in the column, I just replaced mine because the tail lights and hazard lights would not work....
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-11-2007, 01:39 PM   #4
Firefighter
Lightbulb Re: Wiring diagram for Suburban 70 GMC
As far as wiring diagrams the ones for a truck are the same for the tail, turn, brake, and reverse lights.
Yellville, Ar. USA
Old 02-11-2007, 01:39 PM   #5
67Mach1
67Mach1's Avatar
Did you get a replacment column harness from a board vender? I worked on mine to fix the horn and now it works but the brake lights and hazards are shorted out.
is for sale
Old 02-11-2007, 01:40 PM   #6
67Mach1
67Mach1's Avatar
Thanks I will check them out.
Thomas
is for sale
Old 02-11-2007, 02:45 PM   #7
Firefighter
No I got mine from work I work at a parts store, so I got a Delco replacement harness. Not too hard to change unless you have tilt.
Yellville, Ar. USA
Old 02-11-2007, 03:29 PM   #8
Firefighter
The switch is Delco #D6216 GM#1894852. It also comes with the adapter for the flat plug to the half moon style like on our trucks.
Yellville, Ar. USA
Old 02-11-2007, 06:29 PM   #9
67Mach1
67Mach1's Avatar
That is perfect, I have a conact at Oriely's that I need to pick up a NSS also from.
Thanks again I will update with more info, I do not hve a tilt so this might do the trick.
is for sale
Old 03-12-2007, 07:38 AM   #10
67Mach1
67Mach1's Avatar
Ok so it has taken a long time since I first asked about this problem, I searched all over the truck to find the short and never went and pulled the steering column. So this weekeend I got a puller and did it.
Found the white wire to be pinched against the hub adapter and something ellse, exposed wires shorting out direct to ground. Taped them up readjusted everting and VIOLA, I now have brakes and turn signals.
Now if I could just get the steering wheel back on. The teeth of hte shaft seem to be boogered up a bit from prior steering work and I am trying to go back with a mid 70's wheel as opposed to the aftermarket trash some PO had on it.
Thanks to all that offered advice.
Thomas
is for sale
Thread Tools
Display Modes
