73-87 front crossmember
anybody have info on this swap
chevy runs deep
Re: 73-87 front crossmember
x2
i would wanna know also... |
I put one on my 72 bolts right up except one bolt you drill. Went from 6 lug drum to 5 lug disk.
The Older Generation
Here is where I had to re-drill on mine. Be sure and use the inside frame stiffeners from the later model front crossmember. The top hole can just be drilled from either side but I had to enlarge the hole in the frame on the bottom one because there was a nut welded to the crossmember at that location. Other than that it just drops right in. Save the power steering setup & sway bar and brackets from the later one too. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-15-2007 at 03:12 PM. |
chevy runs deep
so 73-87 will work just gotta drill couples of hole's
![]() Join Date: Jan 2005
yes, some say that is the better way than going with the 71-72 fronts. The later models parts may be cheaper than the 71-72.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
Thread Tools | |
Display Modes | |
