Old 02-23-2007, 02:01 PM   #1
68350
68350's Avatar
Help with leaking valve cover???
I have a set of cast aluminum valve covers and the passenger one leaks. I have tried fel-pro gaskets, rubber gaskets, and even silicone, and it still leaks. I have a high volume oil pump, which puts the small block at 60+ psi for driving. Could the valve cover be bad, or is the oil pressure to high? thanks
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 02-23-2007, 02:06 PM   #2
70rs/ss
70rs/ss's Avatar
Re: Help with leaking valve cover???
Cast aluminum should not leak, are the gaskets split? If not then that's not the leak. Sounds like maybe blowby? It the top of the valve cover wet, do you have a breather, with a PCV or just breathers? These are all part of the equation. Lastly, is the cover split, cracked or broken? If none of the above look at the breather system. Oh crap how about baffles? Are the covers baffled, if not it is a straight shot out of the cover.
70rs/ss is offline   Reply With Quote
Old 02-23-2007, 02:20 PM   #3
hvychve
To The Levy
hvychve's Avatar
[QUOTE=70rs/ss;2044701]Cast Lastly, is the cover split, cracked or broken?
I would have to agree with above, If you had tried a new gasket and even went as far as to silicone it. I think I would be looking for a crack, too much oil pressure would only be an issue where there are pressure points, valve cover area is not one ... pull your v/c off again(keeping in mind location where oil was coming from) and look real closely for a crack, v/c may just be junk from someone over tightening it.... goood luck
hvychve is offline   Reply With Quote
Old 02-23-2007, 02:24 PM   #4
cdowns
cdowns's Avatar
inop pcv system is good for valve cover leaks
Old 02-23-2007, 03:36 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
check with a straight edge see if any defect in the casting i had a m/t valve cover that had a little bump barely see it with your eye i changed the cover and wah la no leaks
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 02-23-2007, 05:06 PM   #6
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
Have you tried the steel core valve cover gaskets? I havent tried them yet. Just a thought.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 02-23-2007, 05:28 PM   #7
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Make sure the rail that the valve cover sits on is not cracked, ie the top of the head. Try the steel reinforced VC gaskets if you have not. Also before you use your form a gasket or regular gasket, clean the top of the head and the valve cover with brake cleaner. That insures a good clean surface sealing surface.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 02-23-2007, 07:46 PM   #8
Aarons72s
One last thing. On the motor out of my orange and white, the valve covers always leaked. When I pulled the the motor apart I found that ther was still some casting flash on top of the heads keeping them from sealing.
Aarons72s is offline   Reply With Quote
Old 02-23-2007, 07:49 PM   #9
68350
68350's Avatar
I think the valve cover might be bad, since the motor was professionally rebuilt. I will try a new set of covers and see what happens. thanks
Thread Tools
Display Modes
