Old 03-10-2007, 06:08 PM   #1
1970chevyboy
disc conversion
I have a question is it possible to put spindles and discs brakes from a 1978 chevy silverado into a 1970 chevy c-10 without replacing the whole front end? because when i went to the junkyard someone told me that it wouldnt work without replacing the whole front end and if it did it would eat away at the tires. also would if it was possible just to put the spindles and discs from the 78 would the spindles work with control arms for airbags?
1970chevyboy is offline   Reply With Quote
Old 03-11-2007, 03:27 AM   #2
grayw0lf
Re: disc conversion
I'm quite sure it is possible, but I've nto done it myself. I think it usually involves swapping out the lower ball joints.
Do a search on the FAQ's. You will find a bunch of articles on the subject.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 03-14-2007, 10:08 PM   #3
1970chevyboy
Re: disc conversion
thats good to hear. thanks for the tip.
Old 03-14-2007, 11:14 PM   #4
st1x10
st1x10's Avatar
Re: disc conversion
I believe the ball joints and tie rods have to be replaced due to the taper. Not the whole front end, but you might check the components to see if any are worn or loose while your in there. Currently, I am waiting to get some more money so I can redo the whole front (inner and outer tie rods, ART control arms, Idler, pitman, steer box, spindles, and air bags) and out back some bags and a notch. I figure I will do it all at once and save time and it will be safer as well.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Thread Tools
Display Modes
