Old 03-11-2007, 06:25 PM   #1
CCCC
CCCC's Avatar
Need highway gearing
My 1970 C30 Flat Bed with 350 ci and NP 4 speed manual trans runs out great, but the rear gear ratio is high (probably 4:11) and the engine is turning about 3000 rpm at 60 mph. I need to get into a highway ratio and would rather not revise the rear end gears because sometimes I need the low for pulling.
Does anyone know of a good and relatively simple fix – a bolt-in overdrive or speed change unit (manual control is OK) or a 5 or 6 speed trans replacement? Simplest and strongest is best.
All info and ideas will be appreciated.
Paul
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 03-11-2007, 06:27 PM   #2
dan42
dan42's Avatar
Re: Need highway gearing
There was a thread talking about that yesterday - not sure what it was called but it had some ideas - page back a day or two throught the threads.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-11-2007, 06:28 PM   #3
regal8r
if youre doing alot of highway driving, get a 700r4...unless u NEED your 4spd...
regal8r is offline   Reply With Quote
Old 03-11-2007, 10:23 PM   #4
BCOWANWHEELS
the gear vendors overdrive unit bolts to the rear of the sm 465 tranny and will do the trick but its $$$$$$$
bob
BCOWANWHEELS is offline   Reply With Quote
Old 03-11-2007, 10:48 PM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
I have about the same situation and have been looking around for a NV4500 5 spd which is at least as strong as the 435 and has a .73 overdrive and has a lower 1st gear. You would be at 2190 RPM at 60 MPH (based on your info above) and have great low pulling power.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 03-11-2007, 11:33 PM   #6
snj8198
snj8198's Avatar
I run an NV4500 in my '71. Excellent trans, i strongly recommend it. I run it hard behind my 496 so it's strong, has a 5.61 1st gear which is not as low as the SM465's 6.55 but atleast it is sycronized. There is an earlier Chevy and Dodge version that ran a 6.34 first gear also. With 33's and 4.11's I run about 2200 RPM at 60mph. I better check that for sure but that sounds pretty close.
snj8198 is offline   Reply With Quote
Old 03-12-2007, 01:45 PM   #7
CCCC
CCCC's Avatar
Thanks WorkinLonhorn and snj8198. I have not experienced the NV4500 but will start looking right now. Would rather avoid the cost and hassle of an added unit. 2200 rpm at 60 mph might be just about right in this rig and the pulling power would remain. Can you estimate what a guy should pay for a good condition NV4500? And, a good source? Thanks again.
Paul
CCCC
Thread Tools
Display Modes
