Old 03-11-2007, 07:55 PM   #1
ilovetara
My truck is in pieces!
ilovetara's Avatar
Help...new fuel pump not working...
I am not sure if I installed it right or not, but it doesn't pump the gas at all. Unless my fuel lines are blocked. Can anyone send me pictures of an install.
engine 292 L6
69 Chevy C10 Long
Finally down to the frame!
My Build Progress Pics
ilovetara is offline   Reply With Quote
Old 03-11-2007, 08:02 PM   #2
As2rd
As2rd's Avatar
Re: Help...new fuel pump not working...
did you remember to push the rod up before you stick the tab in? (dont know the proper names) just a thought. The shaft can be mushroomed and can be replace at advance auto. ---Andy
1972 Chevy Truck
350ci/th350 Auto.
Daily Driver
As2rd is offline   Reply With Quote
Old 03-11-2007, 08:23 PM   #3
ilovetara
ilovetara's Avatar
Well, I took the pump off today and tried to feel for a rod, but can't feel one. All I feel is a rounded piece inside there.
69 Chevy C10 Long
Old 03-11-2007, 08:25 PM   #4
rage'nrat638
rage'nrat638's Avatar
you can get a bad new pump
i have bought bad new parts plenty of times
my wife got towed home two weeks ago. i go out and try to start car. no go.
has gas so i figure it's the fuel pump. right..
i go buy a 300.00 pump. jack it up, laying there hating the world. knock on the tank to try to tell how heavy it's going to be right.. sounds like a drum.. hollow?
gas Gage says 1/4 tank?
pour 1 1/2 gal's of gas in start's right up..
i drove my wife to work all week
moral of story check the obvious
rage'nrat638 is offline   Reply With Quote
Old 03-11-2007, 08:28 PM   #5
ilovetara
ilovetara's Avatar
Yeah I will probably just go buy a new pump, but is there suppose to be a rod inside where the pump installs? And what is the proper procedure to install?
69 Chevy C10 Long
Old 03-11-2007, 08:36 PM   #6
As2rd
As2rd's Avatar
That rounded piece is the rod. its a pain to move back up. If you can find someone with a narrow finger to hold it up. I used needle nose pliers to slide it up as far as i can. then i stuck my finger under it, slid it up as far as i can.had a buddy add "sealant to the gasket on the pump" Then I slid the tab under my finger as far as it would go. WITH A QUICK ACTION yanked my finger out and the rod landed on top of the tab. then bolt it up and add the lines and your good to go. ---Andy
1972 Chevy Truck
350ci/th350 Auto.
Daily Driver
Old 03-11-2007, 08:39 PM   #7
ilovetara
ilovetara's Avatar
Oh okay, the rounded piece is the rod. So the tab on the pump goes under the rounded rod.
69 Chevy C10 Long
Old 03-11-2007, 08:45 PM   #8
As2rd
As2rd's Avatar
yeah, but I didnt realize you had a 292. Hopefully they are the same as my 350. It took a few tries but 3rd time was a charm ---Andy
1972 Chevy Truck
350ci/th350 Auto.
Daily Driver
Old 03-11-2007, 08:46 PM   #9
ilovetara
ilovetara's Avatar
Ahhh, I am going out to the garage to try it right now. Will post my findings. Thank a bunch Andy.
Scott
69 Chevy C10 Long
Old 03-11-2007, 08:48 PM   #10
rage'nrat638
yup..
Old 03-11-2007, 09:08 PM   #11
ilovetara
ilovetara's Avatar
Okay, I cannot get the tab under the rounded "rod" at all. I cannot move the rounded rod with my finger, it won't move. I am missing something.
69 Chevy C10 Long
Old 03-11-2007, 09:22 PM   #12
truckdude239
truckdude239's Avatar
sounds liek the rod is in the pump spot it will take some effort easy way might be to turn engine by hand stil rod is in the up position. just my .02
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-11-2007, 09:28 PM   #13
ilovetara
ilovetara's Avatar
Okay so if I have the pump removed, turn the crank by hand, check to see if the "rod" has moved enough to get the pump in correctly. Is this right?
69 Chevy C10 Long
Old 03-11-2007, 09:56 PM   #14
rage'nrat638
sorry i was sleeping
yes that rod run's on a cam lobe just like the lifters.
so if you keep pressure up on the rod and rotate the engine you can get the rod on the low spot of the lobe which will make installing the pump about 85% easyer
Old 03-11-2007, 10:01 PM   #15
ilovetara
ilovetara's Avatar
Hey no problem, I will try this and see if it works! Thanks a bunch
69 Chevy C10 Long
Old 03-12-2007, 11:50 AM   #16
As2rd
As2rd's Avatar
I dunno if you got the rod up yet, but it would be easier to pick up the rod with needle nose pliers. If you drop it youll hear a noise that sounds like dropping a marble from 1 inch off the table. It gets a little time but youll get it. (watch out they are usually brass and can be scarred easily. ---Andy
1972 Chevy Truck
350ci/th350 Auto.
Daily Driver
Old 03-12-2007, 12:02 PM   #17
cdowns
cdowns's Avatar
as far as i know there is no fuel pump rod on 6cyl engines the pump lever runs directly off the eccentric on the camshaft/ it should go on top the eccentric for proper operation
this shows the importance of having and reading a service manual// these guys will talk till they're blue in the face about the rod that doesn/t exist for the 6cyl fuel pump
Old 03-12-2007, 04:58 PM   #18
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
I just put my pump back in a couple of weeks ago.
I renewed both of the gaskets.
I got everything ready to put the pump back on and just before I started I covered the pin with grease and shove it up the hole. It stayed in place just long enough to get the pump in. Worked pretty good.
If you do decide to reach in there with a pair of plyers or a screwdriver, donīt scratch the pin.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 03-12-2007, 11:20 PM   #19
Kager67
what knocking sound?
Kager67's Avatar
I agree with cdowns. I don't believe 6 cylinders have a fuel pump rod. That "bump" you feel is the cam lobe.
1968 C-10
1953 belair two-door post
1955 chevy 3600 big window
1950 studebaker starlite coupe
1968 Impala SS
Kager67 is offline   Reply With Quote
Thread Tools
Display Modes
