Old 03-12-2007, 03:41 PM   #1
bobthecop
bobthecop's Avatar
Frame clean-up
Whats the best way to get the rust off of a frame, short of sandblasting??
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 03-12-2007, 03:53 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Frame clean-up
I use a wire cup on a grinder if im dealing with just surface rust..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-12-2007, 04:00 PM   #3
bobthecop
bobthecop's Avatar
Re: Frame clean-up
Thanks, I've got that, sanding discs, white 120grit plastic abrasive discs, those really remove paint, and I hope will set rid of rust, mostly surface rust. What do you coat the bare metal with, a primer, and then paint all at once??
1972 C-10
Old 03-12-2007, 04:20 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
Re: Frame clean-up
usally I prime the frame and then coat it with por-15
MEMBER #6377
Project "7DEUCE"
Old 03-12-2007, 04:21 PM   #5
bobthecop
bobthecop's Avatar
Re: Frame clean-up
1972 C-10
Old 03-12-2007, 05:31 PM   #6
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: Frame clean-up
I thought that once you wire wheel the surface rust that you can apply the POR-15 directly to the bare frame? POR does mean Paint Over Rust right?
I have little to no rust on my frame and am about to do this myself, I've wire wheeled everything down to bare metal.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 03-12-2007, 05:34 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
Re: Frame clean-up
yes you can put the por-15 over the bare frame I usally prime it cause I take for ever to follow through with the por-15
MEMBER #6377
Project "7DEUCE"
Old 03-12-2007, 05:37 PM   #8
jimmydean
jimmydean's Avatar
Re: Frame clean-up
POR15 can be painted with or without rust. It converts rust that's there while not letting new rust spread. You don't want to paint over flaky rust, but a wire bush to get the loose stuff off is all that's required. Or at least that's what they told me.
I am using only POR15 because my frame doesn't see daylight as long I keep the rubber side down.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-12-2007, 05:38 PM   #9
bobthecop
bobthecop's Avatar
Re: Frame clean-up
Thats good cuz, I'll never get all the rust off, I'll just get the flaky stuff off, where do you get the por-15??
1972 C-10
Old 03-12-2007, 07:18 PM   #10
jlaird
jlaird's Avatar
Re: Frame clean-up
http://www.por15.com/
jlaird is offline   Reply With Quote
Old 03-12-2007, 07:24 PM   #11
cdowns
cdowns's Avatar
Re: Frame clean-up
check your local auto paint supplier too the one near me carries it and with shipping costs its cheaper to buy local// it is far far better to spend a bit more to buy 4quarts compared to a gallon and read the instructions completely before using to get proper results
Old 03-12-2007, 09:05 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
Re: Frame clean-up
I get a quart locally from the paint shop for about 30 bucks..... Couple of words of wisdom from my foul ups...use gloves as it dont come off anything it touches if your doing it in the drive way may want to put something down and last but not least do not leave it open and when you close it use wax paper inbetween the can and lid or it could dry and you will never get the can open agian...
MEMBER #6377
Project "7DEUCE"
Old 03-12-2007, 10:08 PM   #13
yourgrool
67-72
yourgrool's Avatar
Re: Frame clean-up
por 15 tends to fade real easy so i was told so you should probably shoot a coat of chassis black over it to keep it looking good.
yourgrool is offline   Reply With Quote
Old 03-13-2007, 08:34 AM   #14
bobthecop
bobthecop's Avatar
Re: Frame clean-up
Thanks for the info.
1972 C-10
Old 03-13-2007, 09:54 PM   #15
Alvin
Never Done?
Alvin's Avatar
Re: Frame clean-up
I just stripped down my frame using a random assortment of 3M stripping wheels, and various other air tool "bits" you'll find at your local hardware. I'm painting the frame now, and have sprayed three coats of Rustoleum "clean metal primer" and one coat of Rustoleum gloss black. It looks pretty good, although thin in some spots. Hoping another coat of black and it will be good to go. Should be some pics in my build thread by the end of the week.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Thread Tools
Display Modes
