Old 03-12-2007, 10:42 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Swapping leafs to trailing arms?
It looks like I will be changing my leafs to trailing arms. What all is involved?
This is what I can think of:
New front control arm bushings
Coil springs and plates or clamps and bolts
2 rear shock brackets
U-bolts and nuts
Weld on panhard bar-because I will be using the leaf spring rearend
Weld on trailing arm pads
2 crossmember brackets
Anything else I'm forgetting?
Anyone else done this, and have some tips for me?
Maybe I should take some pics of my work.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-13-2007, 01:11 AM   #2
SCOTI
SCOTI's Avatar
Re: Swapping leafs to trailing arms?
There's 2 upper & 2 lower shock brackets.
You'll need the coil spring reinforcement c.member (which also is where the top shock mounts attach).
Front trailing arm brackets (leaf suspensions have the crossmember w/o the brackets).
You can use an ECE Super track bar. It bolts in on the pass side trailing arm & runs across the frame to the driver side (you will need a bracket there).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Thread Tools
Display Modes
