03-13-2007, 10:04 PM | #1 |
Sierra Grande Club
10:1 compression @ 6k feet
I have a question about running 10:1 at altitude (6k). I am using stock cast iron heads, and also want to run 87 octane gas. One shop said no, but another said yes- because it will act like lower compression IE 10:1 will act like 9:1 at this altitude. He also mentioned if I go to sea level I’ll need premium.
Is there any truth to this? Thanks, s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
03-13-2007, 10:08 PM | #2 |
Re: 10:1 compression @ 6k feet
No matter what the compression ratio, air density makes a big difference.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
03-14-2007, 07:04 AM | #3 |
So it will run better up there.Is that bad?And better,yet,at lower altitude.Isn`t that better?I`d say 10:1 is the line between premium and regular.At higher altitude and lowered compression,you`d still want premium to run it best.The main thing is compensating with timing and air/fuel adjustment.I`d say iron heads at higher alt.is a good thing.
03-14-2007, 08:30 AM | #4 |
Chief Honcho In Charge
I have a reman 350 from Jasper. I run premium and I drive normally at 4300 to 5200 feet.
I do not know what my compression is.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
03-14-2007, 09:53 AM | #5 |
I run 11:1 in a 350 with 041 iron heads and 87 octane. My pickup goes from 2800 feet to 9000 feet evelation and on occasion up to 14,000 ft. At lower evelations, I do have to back off the timing or it rattles like a diesel. I presently have over 60,000 miles on this engine. My reason for high compression was to get maximum fuel economy...not for performance. My research has indicated fuel economy and hp is directly proportional to the compression ratio....within limits of course. So I'd say yes you can.
03-14-2007, 10:00 AM | #6 |
How long a wing do you need to get your truck this high?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
03-14-2007, 10:53 AM | #7 |
03-14-2007, 09:58 PM | #8 |
Sierra Grande Club
Thanks for the help. I wouldn’t mind running the 11:1 but still not sure about that. But glad someone has first had experience doing this. What cam are you running BTW? I’m also after the fuel economy (within reason ~ 15mpg) & performance. Are you using a q-jet carb?
The main reason to use the lower octane is the cost. I had a turbo car that only used premium and I live 25 miles from my work and it can get expensive in a hurry. I spent about 4k in fuel a year on one car and it uses 87! If anyone else has some input please help. s/t
03-15-2007, 08:21 AM | #9 |
Do it.The high compression requires less throttle to gain same power.Your carb meters fuel intake.This equals better economy...unless you have no control over that right foot. I think you can find a sweet spot on regular.And,you`ll be hangin`at an average altitude most of the time.It`s not like you drive from the beach to your mountain to get to work.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-15-2007 at 08:22 AM. |
03-15-2007, 08:29 AM | #10 |
At 6K feet with aluminum heads you'd be just fine with 11:1. Aluminum Heads allow you to cheat alittle more compression on pump gas, especially at your altitude.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
03-15-2007, 09:41 AM | #11 | |
Thread Tools | |
Display Modes | |
