Old 03-14-2007, 04:17 PM   #1
Ole Blue 68
Ole Blue 68's Avatar
Drop ?- School Me
I need some advice on the two options I'm looking at to drop my truck. How much difference in drop will there be between using stock height spindles and 2/4 drop springs vs. drop spindles and 2/4 drop springs? If there is not much difference in the drop, then what is the benefit, if any, of going with the drop spindles?
I'm asking because I can pick up a used pair of stock height spindles pretty cheap but if I go with drop spindles I'm pretty much gonna have to buy them new at retail price.
Ole Blue 68 is offline   Reply With Quote
Old 03-14-2007, 04:29 PM   #2
jimmydean
jimmydean's Avatar
Re: Drop ?- School Me
By using spindles, you maintain (for the most part) the factory geometry. Also, if 2.5" isn't enough, you have the option to trim a single coil off the stock springs and get another 1.5" or so.
If you use a 2" spring, then you will need to have the front end adjusted. If you decide that a 2" spring isn't that much lower than your saggy old stock springs, then you end up buying the spindles anyway.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-14-2007, 09:39 PM   #3
BowTieOgre
What I was told is that you can get away with a 2" spring drop without affecting your handling much but if you want to go lower its best to get the drop spindles like JD said.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 03-14-2007, 11:10 PM   #4
Ole Blue 68
Got it, so if I want to be more aggressive and go 3/5 then I'd be better off with the drop spindles?
Old 03-15-2007, 10:08 AM   #5
Ole Blue 68
Ok, just one more question. (I feel like Columbo...)
Some of the spindle packages that are out there include tie rods/ball joints for 63-70 while others sell an "upgrade" with tie rods/ball joints for 73-87. Which would you all go with?
Old 03-15-2007, 10:24 AM   #6
smh292
Either way you should still have the front end aligned after you modify it, unless you want to buy new front tires as well.
www.diverserides.com
WTB 67-68 SWB, 350, Auto, Coil frame, Discs up front - PM me with details
smh292 is offline   Reply With Quote
Old 03-15-2007, 01:34 PM   #7
pat
pat's Avatar
I would definitely go with the drop spindles up front, that way you can always get springs when you decide you havent gone low enough..
Seems easier to get the 63-70 tie/rod ball joints setup, and probly a good idea to replace them.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 03-15-2007, 03:49 PM   #8
Ole Blue 68
Yeah, I'm leaning towards the drop spindles and I figured I would replace the tie rods/ball joints at the same time. I was just wondering if going with 73-87 is really an upgrade.
Old 03-15-2007, 03:53 PM   #9
BowTieOgre
Im not sure if it is an "upgrade" but I was told the availability of the '73-87 model parts makes it a good idea.
Old 03-15-2007, 04:00 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I think the 73-87 ball joints are cheaper and more widely available.I think that is the reason for going to the 73-87.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-15-2007, 04:04 PM   #11
Ole Blue 68
Thanks for the responses. One of the sites I was checking out said that and it made sense to me.
Thread Tools
Display Modes
