Old 03-25-2007, 09:27 PM   #1
turner15
restoring a steering wheel
Has anyone ever restored a steering wheel? I only have a couple of cracks in mine and would like to try. I was thinking of fibreglass bondo in the cracks and the SEM paint I used on the headliner?
Any advice would be great.http://67-72chevytrucks.com/vboard/i...es/redface.gif
turner15 is offline   Reply With Quote
Old 03-25-2007, 10:16 PM   #2
larry may
Re: restoring a steering wheel
This was talked about in the paint forum long while back. JB weld was disscussed. Do not know what the results were there . I tried it with the Quick JB weld. took a couple of applications with wax paper under the wheel To catch the run if any. Sanded the wheel and sprayed with can spray. Is not a great job but did look better than the cracks. Should have taken a picture . My skill with paint and such is challanged. Guy that bought the truck did not notice the patch even when I asked him. Good Luck
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 03-25-2007, 11:05 PM   #3
sjarrett71
sjarrett71's Avatar
I believe Eastwoods or LMC or someone sells an actual steering wheel repair kit. It has some epoxy stuff in it.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 03-25-2007, 11:22 PM   #4
72CSTC5
72CSTC5's Avatar
You could use some 3M 8115 panel bonding adhesive. Would work for you but you have to buy a pricey gun to dispense the adhesive for you.
72CSTC5 is offline   Reply With Quote
Old 03-25-2007, 11:30 PM   #5
Luis_gz06
Luis_gz06's Avatar
Golden State Parts also has a repair kit for wheels.
Luis_gz06 is offline   Reply With Quote
Old 03-26-2007, 12:26 AM   #6
Shane
Shane's Avatar
Fiber glass resin and activator. No fiber cloth. Mix the resin, apply with something like a Bondo spreader that's been cut down to allow for smaller areas. Then allow the resin to cure, sand to shape, then prime and paint.
Shane is offline   Reply With Quote
Old 03-26-2007, 01:35 AM   #7
Rollie396
someday it will be done!
Rollie396's Avatar
I read an article a few days ago (that I can't find now) about a company you can send your wheel to.They strip it down to the wire,remold it and put a marble lookin type finish on it.It looked pretty good and I'm sure it wouldn't cost much .
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 03-26-2007, 09:21 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Eastwood [www.eastwood.com] sells a kit, the "Complete Steering Wheel Restoration Kit," p/n 52194Z for $30. I used the pic in their catalog and got most of the key components at Ace hdw,Pep Boys, Home depot, etc. for less. Ace had the 2 -part filler -- PC7 Epoxy. The stuff worked pretty good filling in the grooves I filed thru the cracks. I've sanded it down but still have to do some touch up and refilling/sanding, before I prep it and paint.
I'm still using a "slime green" (Seafoam) spare wheel on my truck and it works OK but looks like ****.
Old 03-26-2007, 10:12 AM   #9
John Fabris
TOTY 2006
John Fabris's Avatar
I used JB weld on my wheel, then sanded it smooth, and we painted it the same color blue (same paint) as my truck...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 03-26-2007, 10:20 AM   #10
Shock_Me
Shock_Me's Avatar
I'm in the process of restoring a 69' wheel right now, with the kit from Eastwood. It basically comes with a resin and a hardener, cleaner, and etch primer.
Like the others have said: mix resin and hardener, apply, allow to harden, sand and shape, prime and paint.
I haven't primed or painted yet, but the repair looks real good. I'll post pics tonight. As far as how long it will last? Who knows...but the cracks I had were about half an inch wide, so a couple of hair-line cracks would definitely look better than that.
Pete
Shock_Me is offline   Reply With Quote
Old 03-26-2007, 06:09 PM   #11
Biff
GM Gypsy
Biff's Avatar
I have heard that the stuff from Eastwood works good. '68orangesunshine is right though, check out the pic and try to find it at the big box stores. http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
1972 Custom 10 Deluxe LWB 4x4
2003 Power Wheels Barbie Jeep (2 daughters ya know)
2004 Silverado Crew Cab Z71- Sold
Here's to your coffin...
May it be built of 100 year old oaks which I will plant tomorrow...
Biff is offline   Reply With Quote
Old 03-26-2007, 06:58 PM   #12
Shock_Me
Shock_Me's Avatar
This is my progress so far with the Eastwood kit. Pics are a little blurry, but you get the idea.
Thread Tools
Display Modes
