Old 03-26-2007, 03:31 PM   #1
neal
New Member
Question steering knuckel
I bought a gmc paul disc brake conversion kit for my 69, the ft. end came apart very nicely-should have been a clue. installed new knuckel, when i torqued it, the upper balljoint ( upper and lower new) nut went a thread past the cotter key hole, perhaps after market tolerance, the lower lined up normal. The knuckels feels to tight, I don't have a spring scale but I would guess it takes 15-20 lbs to move it. The dums I removed folped. makes me think upper ball joint is to narrow, if so, that makes me wonder about the lowers? any suggestions??
neal is offline   Reply With Quote
Old 03-26-2007, 03:55 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: steering knuckel
I believe they are designed to use the 1971 and 1972 ball joint. The shaft on the 71-72 joint is a bit larger in diameter and a little longer, but they will bolt in to the 1969 control arm.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 03-26-2007, 04:07 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Thats not too unusual when installing drop spindles. Just remove the nut and install a flat washer under the nut to take up the slack so the hole falls inside the castle nut's notches..
Old 03-26-2007, 04:26 PM   #4
neal
New Member
what about how tight should the knuckle feel?
Thread Tools
Display Modes
