03-26-2007, 09:27 PM | #1 |
Timing light will not flash
Just had a distributer problem that you guys helped me fix (thank you!!), and I grabbed my timing light to set the timing. No flash from the timing light, and I figured my ancient timing light just finally decided to die. Picked up a new Craftsman light and the same thing, no flash... nothing at all. Both are induction lights.
I pulled the number one plug and checked for spark, sparks ok. I checked to make sure that I had the battery leads attached correctly, they were. Also moved the induction pickup up and down the #1 wire. Any idea why I can not get my timing light to flash? |
03-26-2007, 10:22 PM | #2 |
Active Member
Re: Timing light will not flash
mine did that, el-cheapo brand. Had an on-off button that would stick.
just my experience J |
03-26-2007, 10:26 PM | #3 |
Msgt USAF Ret
My light has an arrow on the inductive pickup that says, toward the spark plug. If it isn't that way it won"t flash. It also has a small switch on the housing that has to be pressed for it to work. Have you tried it on a different vehicle?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-27-2007, 08:47 PM | #4 |
Some days I worry about me...
Tested it with my 78 C-30 (thanks VetteVet), worked perfectly. Went back to the 67 C-10 and now it works... Either I have lost what few marbles I had left, or that light was trying to bug me! Thanks! |
03-27-2007, 10:24 PM | #5 |
[QUOTE=68_Step;2096644]...that light was trying to bug me![QUOTE]
I heard that. My also ancient Craftsman (Penske) light used to do that from time to time. Drove me nuts. It finally became the victim of an acute throw-down fit, and got replaced by one from the AAP store two blocks down the street. I guess 30 years is all you can expect from a $25 timing light. |
03-27-2007, 11:10 PM | #6 |
72 chevy
Funny but thats what fixed my craftsman timing light (an acute throw-down fit) its worked great every sence.
Ed |
Thread Tools | |
Display Modes | |
