Old 03-26-2007, 10:39 PM   #1
C-10FREK
Cab to low driveshaft hits??
I bagged my 82 and when I dump the air out the the drive shaft hits the rear of the cab,it hits right at the very end of travel, is this normal. Do I have to put a channel in the rear of the cab for that, like I did for the gastank crossmember?
C-10FREK is offline   Reply With Quote
Old 03-26-2007, 11:11 PM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: Cab to low driveshaft hits??
if it hits, i'd notch the cab.
by the sounds of it, you might be able to just take a heavy hammer and force the notch
IvelDesigns is offline   Reply With Quote
Old 03-27-2007, 12:11 AM   #3
04 orange
04 orange's Avatar
Your going to have to clearance it some way. I cut 4" out of the back of my cab for clearance. One of my friends had his drive shaft hitting like that and never did anything about, it broke a few months later.
04 orange is offline   Reply With Quote
Old 03-29-2007, 02:00 PM   #4
XXL
Seņor Member
XXL's Avatar
See this post.
XXL is offline   Reply With Quote
Old 03-29-2007, 09:38 PM   #5
C-10FREK
I might be able to just hammer it in, If not I guess its time to break out the saw Its good to know that I'm not the only one that has run across this.
Old 03-30-2007, 07:28 PM   #6
69face
69face's Avatar
you may be able to change the pinion angle to correct it depending on the type of setup you have
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Thread Tools
Display Modes
