Old 03-29-2007, 06:58 AM   #1
Curbstone Mech
Active Member
3 speed on column hang up issues
I know there have been posts on this before but I couldn't find them on a search. When the linkage gets stuck, there's away to resolve the issue for quite awhile by removing a nut and bolt in the linkage under the hood, placing a drill bit between the two holes to line them up, then tighten everything back together.
I could probably wing it with this knowledge, but I don't get much time before dark and I want to get it right.
Thanks for any help!
Curbie
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 03-29-2007, 11:49 AM   #2
northerngmc
northerngmc's Avatar
Re: 3 speed on column hang up issues
The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Site related > FAQ > FAQ Truck Tech
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 03-30-2007, 02:34 PM   #3
Curbstone Mech
Active Member
Blane-
Thanks alot, that was exactly what I was looking for. We tried it last night and it worked perfectly!
68 short fleet
700r4 351;1 posi
Last edited by Curbstone Mech; 03-30-2007 at 02:35 PM. Reason: spelling, what else
Old 03-30-2007, 04:28 PM   #4
northerngmc
Did you do it with the column in the truck?
I need to tackle this job as well, hopefully in the next week.
Blaine
Old 04-02-2007, 07:40 AM   #5
Curbstone Mech
Active Member
Yes I did. I even found a set of bushings, Jim Carter has them if anyone is interested. I still have issues, tho. Worked on it yesterday, put in the new bushings, but still only have first and reverse gears. I gave up when it started to rain hard.I'll try again one afternoon this week.
68 short fleet
700r4 351;1 posi
Old 04-02-2007, 10:15 AM   #6
northerngmc
I tackled mine this weekend. Ended up changing the column as the previous owner had broken the shifter and then damaged the top part of the column. My replacement column is in and seems to shift but I haven't tried backing it out of the garage yet.
I'm now trying to figure out the horn. The PO had an aftermarket steering wheel poorly attached. I now have an original wheel attached, but I seem to be missing a piece for the horn. Yeah and the horn is missing too!
Blaine
Thread Tools
Display Modes
