Old 03-30-2007, 08:48 PM   #1
71jimmy
71jimmy's Avatar
Ebrake help?
Now that I have my 6in lift I need to figure out how to get the ebrake working. The rear cables are too short now. Is there anyone that has tackled this issue?????
And yes, I want my ebrake working. I looked at the inline tube site and it appears the shortbed and blazer rear cables are the same. Longbed cables mount differently inside the drum. They don't list length of the cables. I was hoping the cables from a longbed would work.
Any suggestions?????
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 03-31-2007, 01:38 AM   #2
IGOR
IGOR's Avatar
Re: Ebrake help?
inline tube can make custom length cables - I would start there
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 03-31-2007, 02:33 AM   #3
71jimmy
71jimmy's Avatar
Re: Ebrake help?
Thanks Igor, I'm curious to know if someone has used a cable from another vehicle that works. Last resort will be to have them custom made. Also interested in knowing how much longer they should be. 6in lift = 6in extra cable length?
Old 04-01-2007, 08:11 AM   #4
vtblazer
vtblazer's Avatar
Re: Ebrake help?
IIRC there's a thread in the 4x4 section that has the info your looking to find.
vtblazer is offline   Reply With Quote
Old 08-18-2008, 09:28 PM   #5
Critter
Future TOTM Winner
Critter's Avatar
Re: Ebrake help?
I'm bringing this post back. By the way, I searched around the site for a while but never really found my answer. My K5 has cables that are around 40 inches long (not including the few inches that are inside the drum). First off, I'm not sure if these are the originals cable or not. Specifically, has anyone used ebrake cables from a long bed and had any success? I have a six-inch lift.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 08-19-2008, 03:37 PM   #6
71jimmy
71jimmy's Avatar
Re: Ebrake help?
Holy Schmoley! It's alive again.
Never did get or find an answer. Put it on the back burner since I'm doing rust repair and she hasn't moved from the garage.
Old 08-19-2008, 03:46 PM   #7
bigrey6306
bigrey6306's Avatar
Re: Ebrake help?
wow, I was about to ask this same question...
I need my ebrake hooked up
and critter what is all that stuff stacked between the axle and springs in your pic??
71' K5 Blazer
6 in lift
36x14.50 Mud Grips
Crate 350 with headers
Needs a paint job!
bigrey6306 is offline   Reply With Quote
Old 08-19-2008, 04:08 PM   #8
Critter
Future TOTM Winner
Critter's Avatar
Re: Ebrake help?
HAHA! Good question! Please see here:
http://67-72chevytrucks.com/vboard/s...d.php?t=303419
Thread Tools
Display Modes
