Old 04-01-2007, 10:58 PM   #1
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
Half ton power drum brakes?
Hiya! My 1967 has the factory all-wheel drum set up (and manual of course). I was just wondering, could I add a power booster from a power disc brake truck and stick it behind the master cylinder of a drum brake truck?
I know you're probably thinking, why would you do something like that? Just go disc brakes! Well, I'm not ready for the entire swap yet ($$$!) but I have a booster lying around along with the correct bracket. Just curious, I might go through with it if you folks think it'll work.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 04-01-2007, 11:02 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Half ton power drum brakes?
do it..you won't even need disc brakes then,,
it's a direct fit.
you just need the rod from the pedal and the booster..your master will bolt right on
and a vacuum line ran to the intake
rage'nrat638 is offline   Reply With Quote
Old 04-01-2007, 11:02 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
I ran a disc booster with front drums on my 68. It worked great sometimes. The booster had a diaphragm leak, so I had some issues, but it was due to faulty parts.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-01-2007, 11:18 PM   #4
GMCMAX
Active Member
GMCMAX's Avatar
Here's a link to the post with pics on a 69 that I did this to.
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 04-01-2007, 11:38 PM   #5
ThatOneBlue67
Ha ha sweet! I'm gonna do that then. Thanks!
"The Hurricane"
1967 Chevrolet C10
Thread Tools
Display Modes
