Old 04-07-2007, 11:33 AM   #1
70GMCer
70GMCer's Avatar
12 Bolt carrier size?
I have an open 12 bolt on my 70 w/373 gears. Plan on installing a posi and was wondering if the 373 gearing will except a 2 or 3 series carrier or either one?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-07-2007, 11:51 AM   #2
powell72
powell72's Avatar
Re: 12 Bolt carrier size?
You can get 3.73's in a 3 or 4 series carrier. Our trucks didn't have any 2 series gearsets.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-07-2007, 03:15 PM   #3
How about 3.42s?Which carrier is required for that ratio?
Old 04-07-2007, 03:20 PM   #4
70GMCer
70GMCer's Avatar
So either a 3 or 4 series will work with that gearing?
1997 GMC Sierra Ext
1965 Mustang
Old 04-07-2007, 03:25 PM   #5
BowTieOgre
3.73 and up is a 4 series but I think I heard you could put 3.73 gears in a 3 series as long as you added some sort of spacer. Unless you ever plan on going with a 3.08 or something later on just get a 4 series and call it good.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 04-07-2007, 03:32 PM   #6
71chevylowrider
71chevylowrider's Avatar
if I remember correctly, a series 3 does 3,07/08 to 3.73 & a series 4 starts at 3.73 & goes up to 4.56
71chevylowrider is offline   Reply With Quote
Old 04-07-2007, 04:20 PM   #7
mnunn454
mnunn454's Avatar
With Chevy car rear ends the breaking point is different (numerially lower), but for our trucks, 3.42 and down take a 3 series carrier. 3.73 and up take a 4 series carrier, just as BowTieOgre said.
When I bought my Eaton posi and new 3.73 R&P I had to make the tough choice. I opted for performance over mileage and went with the 3.73 over the 3.42, and therefore had to go with the 4-series carrier. Since upgrading to the 454, now I wish I'd gone with the 3.42s and 3 series carrier.
You can run a 4 series R&P on a 3 series carrier, if you use a ring gear spacer or buy a "thick" style ring gear. This arrangement should be fine for stock/normal use.
Check with the R&P sellers if you're still in doubt.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Thread Tools
Display Modes
