Old 04-07-2007, 05:51 PM   #1
young grasshoppa
young grasshoppa's Avatar
Question Excessive vibrations?
My 72 C-10 (350/3sp) is vibrating badly under acceleration. Before there was only a slight vibration, but now it shakes the whole truck. It is most noticeable from a stop. At cruising speed it is fine (until acceleration).
What's most likely wrong?
young grasshoppa is offline   Reply With Quote
Old 04-07-2007, 06:43 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Excessive vibrations? :confused:
Do you have a 2 piece drive shaft? I would think it's the center support bearing, but that usually causes a vibration even if you aren't accelerating (driving) You could check it if you have one just to rule it out.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-07-2007, 07:01 PM   #3
cdowns
cdowns's Avatar
check for worn broken motor mounts
Old 04-07-2007, 07:11 PM   #4
jhow66
jhow66's Avatar
U-joint or center support. Better get it fixed or you are in for a surprise.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-07-2007, 07:19 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you sit still, left foot on the brake, right one stabbin the gas... do you feel the same vibration?
If so, you need to look towards a tune up.
Old 04-07-2007, 07:25 PM   #6
jhow66
jhow66's Avatar
Check this:
http://www.napaonline.com/masterpage...ng+%26+Support
Old 04-07-2007, 07:27 PM   #7
jhow66
jhow66's Avatar
And this:
http://www.napaonline.com/MasterPage...t+Transmission
Old 04-07-2007, 11:42 PM   #8
young grasshoppa
Ha Ha
Surprise it was! I tried going for another spin, and barely made it down the road. I shattered the drive shaft off of the U Joint. There is play is the support bearing.
Luckily it was just down the road from the house. So now there are two things to fix.
Thanks for the help
Thread Tools
Display Modes
