09-06-2002, 11:55 AM | #1 |
Got my Carb Powder Coated
Here is a picture.
09-06-2002, 12:00 PM | #2 |
Here is another picture.
09-06-2002, 12:22 PM | #3 |
One more.
09-06-2002, 01:17 PM | #4 |
Saving 1 truck at a time!
Very cool! I like it! Your motor looks great.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
09-06-2002, 01:55 PM | #5 |
Thats just prime!
Your motor looks good, just a rookie here but, what is the significance of getting it powder coated, reflect heat?
thanks
*69 GMC short bed stepside with a wimpy six that can barely pull itself. *99 Chevrolet Camaro Z-28 1 Bad 5.7ltr LS1 |
09-06-2002, 02:32 PM | #6 |
Giddy up giddy up...
Nice engine! Just hope the air cleaner doesn't cover the beauty now
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site... |
09-06-2002, 03:23 PM | #7 |
Here is a picture with the air filter on.
09-06-2002, 03:26 PM | #8 |
Pumkin Truck, the powder coat should last longer then paint would.
09-06-2002, 04:23 PM | #9 |
Post Whore
That really sets it off well. What did it cost to powdercoat?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-06-2002, 05:51 PM | #10 |
Im confused I thought you had to bake on the finish. Wouldn't it cook the carb??? How'd you only get the parts you wanted? Do you just mask it like you would when you paint anything else?
Brandon |
09-06-2002, 06:20 PM | #11 |
Yukon Jack, a friend of mine powder coats carbs, so it didn't cost me much. The powder doesn't cost much, I got the powder from http://www.eastwoodco.com
09-06-2002, 06:34 PM | #12 | |
Brabra, It is baked on. You have to take the carb apart, all the plastic and rubber parts have to be taken off. Each part is powder coated, then you put it all back together. You do have to mask off the part you don't want coated. I polished the metering blocks and baseplate and clear coated them. Last edited by 383 Stroker; 09-06-2002 at 06:36 PM. |
09-06-2002, 09:08 PM | #13 |
Powder coating is easier than paint, if you are set up to do it. I powdercoat everything that will fit in the oven (garage oven...don't use your house one). If anyone is interested in getting powdercoating done on smaller parts (that will fit in a typcial household oven) send me a PM.
69 SWB LT1/4L60E www.classicplace.com |
09-06-2002, 09:34 PM | #14 |
stroker the carb looks good. I have a question off topic. What kind of shocks are you running? drag shocks or regular gas?
69-C10 LWB 71- fleetside shortbed It's a shame stupidity isn't painful Never play leapfrog with a unicorn |
09-06-2002, 10:12 PM | #15 | |
09-06-2002, 11:05 PM | #16 |
I think your carb looks niiiice. I was wondering how to detail everything in the engine compartment. Is it aluminum? Can you powdercoad aluminum?
Thanks, Brandon |
09-06-2002, 11:38 PM | #17 |
Aluminum is not a problem to powdercoat, but you should bake it first to let the oils gas off. Otherwise, it will bubble up when the coating is cooked.
09-07-2002, 10:11 AM | #18 |
Black 72 Chevy
Those pics of the engine are very nice.
09-07-2002, 11:08 AM | #19 |
Powdercoat
Very sharp lookng power plant.
Mark
'68 Fleet LWB orig 307 .030 over GM Hei/w Accel Super coil orig. stock TH 400. _______________________ “What we do for ourselves dies with us. What we do for others and the world remains and is immortal.” Albert Pine English author d.1851 |
09-07-2002, 05:26 PM | #20 |
in WAY over my head
thats hot, I didn't know you could really do that to a carb. keep up the good work!
Thread Tools | |
Display Modes | |
