Old 04-10-2007, 05:36 PM   #1
JkC824
replacing fuel tank selector valve
is there a special tool for taking of the fuel tank selector valve? I can't get any wrench up in there to get it off.
JkC824 is offline   Reply With Quote
Old 04-10-2007, 05:52 PM   #2
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
Re: replacing fuel tank selector valve
IIRC all you need to do is reach behind it and squeeze the two tabs, one on top, one on bottom, and push it out.
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 04-10-2007, 07:48 PM   #3
JkC824
its not the switch in the cab its the valve under the frame rail. but thank you anyway.
Old 04-10-2007, 08:06 PM   #4
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I used a regular box end and open end wrench when I removed mine a couple of years ago. It was kinda slow going, but fortunately the threads were clean. Putting them back on and tightening them was even tougher. Removing the rubber lines from the valve helped.
I don't know if a special tool exists.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-10-2007, 08:24 PM   #5
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
You probably have some bad body mounts. Put a 2x4 under your rocker (from front to rear, the long way) and lightly lift it with a jack. You'll be able to use a wrench on the top of the bolts then. The last time I did it, I used a ratcheting box end (gearwrench brand) and it was much easier than the time I did it before that.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 04-11-2007, 05:08 PM   #6
JkC824
I would like to thank you and i will try my best.
Old 04-13-2007, 11:35 PM   #7
chevyowner
just be very careful in installing the gm fuel tank selector valve. be sure its properly done so as not to have problems. good luck
chevyowner is offline   Reply With Quote
Thread Tools
Display Modes
