Old 04-10-2007, 06:19 PM   #1
ncC20
A-arms for c20
Hi im in the process of converting my c20 8 lug to a 5 lug. I've got new spindles from ECE new rotors upper and lower ball joints inner and outer tie rods calipers and hoses. Once i started putting it all together i noticed the shafts that run through my upper a-arms is completly stripped out not only is the shaft stripped but the threads are gone out of the a-arms. So my ? is where can i get a tubular set of a-arms for my C-20
ncC20 is offline   Reply With Quote
Old 04-10-2007, 06:43 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: A-arms for c20
Take a look at Classic Performance Products. I just got my tubular A-arms from them, as well as the tubular motor mounts for my LS-1; all for my 68 Chevy truck. I haven't installed yet, but they look dang good on the floor. http://www.classicperform.com/
piecesparts is offline   Reply With Quote
Old 04-10-2007, 07:14 PM   #3
ncC20
Re: A-arms for c20
Will the a-arms for the c10s work on my truck ?
Old 04-11-2007, 03:53 AM   #4
Aarons72s
Re: A-arms for c20
3/4 ton upper A arms are not the same as 1/2tons. Just go get some used ones off of a 73-87 3/4ton gm truck. They are the same as 67-72 3/4ton arms, that is if you dont find or decide not to go tubular. Good luck.
Aarons72s is offline   Reply With Quote
Old 04-11-2007, 08:36 AM   #5
extd56
extd56's Avatar
Re: A-arms for c20
Are the lower arms the same on the 73-87 3/4 ton trucks also? Is that a direct bolt on for them? I am thinking of upgrading my 69 Chevy to disc brakes and would like to just change the spindle if the 73 and up trucks will interchange with my 69 a arms. Thanks
extd56 is offline   Reply With Quote
Old 04-11-2007, 06:40 PM   #6
ncC20
Re: A-arms for c20
Ne one no where u can get tubular a arms for a 3/4 ton c20
Thread Tools
Display Modes
