Old 04-14-2007, 10:56 AM   #1
vern350
like a rock
vern350's Avatar
15" rims on 3/4ton
will 15" rims fit a 3/4 ton 4x4? Thanks
vern350 is offline   Reply With Quote
Old 04-14-2007, 02:57 PM   #2
84lwb
84lwb's Avatar
Re: 15" rims on 3/4ton
I would say no,probably have a HARD time finding 8 lug 15" rims,and they may not fit over your brakes.
84lwb is offline   Reply With Quote
Old 04-14-2007, 03:27 PM   #3
fourty1
fourty1's Avatar
Vern,
I have a 67 3/4t, 350-th400, Eaton diff. w/4;57 gears, 8-lug w-16" & 32" commercial tires.
I did the 2 1/2 dropped spindles (8-lug !) 1" springs, & 4" drop spring in the rear. I replaced the 16" whls w 17" Weld Coneheads (8-lug) & 28" Continental tires.
Messed up the gear ratio !, gas mileage & turning about 3200 @ 55mph !!
Now I need to replace the Eatin diff, w/ a Dana and try to get some 3:08 gears to get everything in line again...
Not sure if this answers your question ( kinda vague, you are probably running a Dana, just check your gear ratios, or maybe it doesn't matter ), but one thing DOES lead to another. here's the truck. first is before, second is after:
-41-
1941 Chevy 1/2 ton Street Rod: 327 cu,/350 auto, 'Stinger ' - JULY 2007 CUSTOM CLASSIC TRUCK magazine.
1967 Chevy 3/4 ton standard bed, 350 cu./400 auto,
w/ 83 - 3:43 rear end...sips gas....
fourty1 is offline   Reply With Quote
Old 04-14-2007, 05:56 PM   #4
vern350
like a rock
vern350's Avatar
not 2 sure if that helps, but killer 67. I dont think 15" rims will clear the brakes. Found some 35x12.50x15 all terrans and just currious if 15" rims will work. Anyone?
Old 04-14-2007, 10:27 PM   #5
oldgmc
oldgmc's Avatar
On a 79 3/4 I have 8 lug 15" they are about 33" ar I think. I did not buy they came with the truck.
oldgmc is offline   Reply With Quote
Old 04-15-2007, 09:02 AM   #6
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
They will work with the rear fine. Its the front calipers that need a little grinding to get them to fit nice.
http://www.coloradok5.com/d60calipergrind.shtml
Here is a Summit part number for the 15x8 8 lug rim for 34.88 per rim USW-70-5880
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 04-15-2007, 11:07 AM   #7
vern350
like a rock
vern350's Avatar
h'mm, i guess i'll have to think about. Thanks for that last link and all the reply's, much appreciated.
Old 04-16-2007, 05:13 AM   #8
bb1979
bb1979's Avatar
g'day from the land downunder lol
15" rims on a 3/4 can be done. I have a 1979 3/4 ton 2wd with 3" drop spindles 2 inch dropped coils and 15" rims with 30x9.5x15 Radial T/a's on the front. The spindle and the brake caliper do need grinding but nothing that will cause problems. The rears fit fine. Actually the only reason I had to grind was because of the offset on my rims and the drop. I've been running this combo for 5 years now no problems just install new brake pads before grinding so the caliper is moved as far outboard as it will ever go.
Having said all this my old mans 3/4 uses a set of 15" rims with no grinding and only a 2" set of cut coils but his rims are set further outboard
bb1979 is offline   Reply With Quote
Thread Tools
Display Modes
