Old 04-15-2007, 07:59 PM   #1
1969k10stepside
What did you get done? 4/15/07
I finally removed the other wheel tub and bedside from the shortbed,relocated the truck bed to the garage,from the shop.I also got the bottom end done on the 360 (bored out 350) for the 71.Mowed the yard......
1969k10stepside is offline   Reply With Quote
Old 04-15-2007, 08:17 PM   #2
lbpd719
Zappaphile!
lbpd719's Avatar
Re: What did you get done? 4/15/07
bitter wind out here today, got plugs/wires done, also took out junk newer style GM Radio, and reinstalled factory ashtray. Fixed a good sized vac leak at the carb..
posted pic's of the truck finally, and updated my signature line on the board
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 04-15-2007, 08:17 PM   #3
Finally did some stuff on the truck. Did some patching/welding on the bed where I added my fuel filler.
http://67-72chevytrucks.com/vboard/s...=221437&page=2
Ran out of welding gas, so I worked on the template to cover the filler neck in the bed. Helped a friend work on the GPS in his Caddy. Worked on my compressor and fixed a pulley problem on the motor (I hope). Hung out with a board member EdB this afternoon.
Oh yeah, watched it rain and blow alot both days.
Palf70Step is online now   Reply With Quote
Old 04-15-2007, 08:18 PM   #4
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Talking Re: What did you get done? 4/15/07
NOTHING !
here in southrust virginia it's 37 degree's it has almost flooded it rained all night last night then today it snowed !! my garage has four season climate control in spring it cold in summer its hot in fall it's wet and cold and in winter it's froze !!
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 04-15-2007, 08:28 PM   #5
DUD2STUD
DUD2STUD's Avatar
Rebuilt my bed dolly, installed rear lowering springs, finished sanding rear frame and shot some silver paint on it oh and I got the garage cleaned up
DUD2STUD is offline   Reply With Quote
Old 04-15-2007, 08:32 PM   #6
msgross
msgross's Avatar
Cut down a tree, installed new swings for the kids, took the family out to eat and never made it to the junkyard due to weather.... I'm taking leave all next week so ask me again next sunday!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-15-2007, 08:36 PM   #7
Piece of Work
Cultural Infidel
Piece of Work's Avatar
I dug 33 post holes and installed 240' of vinyl fence. My shoulders are killing me!
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 04-15-2007, 08:42 PM   #8
71MUTT
Can't ReMember
71MUTT's Avatar
Took out the old dash. (First one)Swapped some of the pieces around................Got the second one ready.
Adversity doesn't test your character; it reveals it.
71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running )
71MUTT is offline   Reply With Quote
Old 04-15-2007, 08:47 PM   #9
ostncoln
ostncoln's Avatar
pulled the rubber mat, insulation, and seat belts out of the 71's floor to see just how bad the rust is that i hope i will be getting some work done on this week. cab corners rockers and floor patches looks like. also topped of the brake fluid that was almost dry.
oh and does anyone know what the bracket on the passenger side in the corner of the cab is for? it is on the back side of the door jamb about as high up as the seat back. is it for a jack or what
ostncoln is offline   Reply With Quote
Old 04-15-2007, 08:49 PM   #10
sick69
sick69's Avatar
I got the passenger cab corner on,inner and outter rockers. I did the driverside last week end. I'll get a skim coat of filler on them this week and sanded down. Chassis comes home next saturday.
Then the real fun starts!!! Start cleaning it and preping for paint.
That's it for this week end. Oh yeah almost forgot,,,, cleaned up the mess from the cab corners/rockers project in the garage. Swear there had to have been 50 pounds of dirt in there. I did find a huge wasps nest in the passenger side rocker.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 04-15-2007, 08:55 PM   #11
2nd_wnd
2nd_wnd's Avatar
New exhaust on the DD plus fixed the header leak with aluminum header gaskets up top and used an extra set of flanges of the lower part of the header to use as a gasket between header and exhaust.
For your info it works great
72 LWB
2nd_wnd is offline   Reply With Quote
Old 04-15-2007, 08:59 PM   #12
Piece of Work
Cultural Infidel
Yes, it is for the jack.
posted via La-Z-Boy
-Mark
Old 04-15-2007, 09:14 PM   #13
71MUTT
Can't ReMember
71MUTT's Avatar
Frank
It was probably holding it together.
Old 04-15-2007, 09:19 PM   #14
centsless
sufficiently talented fool
centsless's Avatar
I got the windows tinted in the truck last week, and Saturday I put the ECE sway bar lowering brackets on. I then installed the sway bar with new Energy suspension bushings and brackets. I also put some drywall up in my kitchen, still have to spackle it. Sunday I didn't do anything but cruise around here on the computer....
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-15-2007, 09:22 PM   #15
fast50ranger
fast50ranger's Avatar
Pressure washed my engine bay because my engine will be going back in next weekend. Oh yeah and I cut grass.
fast50ranger is offline   Reply With Quote
Old 04-15-2007, 09:30 PM   #16
corn
Spent almost all weekend getting some work done to the garage. At least I got to be IN the garage. The truck sat outside & pouted the whole time too...
corn is offline   Reply With Quote
Old 04-15-2007, 09:53 PM   #17
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Took the 69 out for its first drive today.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 04-15-2007, 09:58 PM   #18
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
Well, nothing today. But YESTERDAY...
I'm driving through town and my starter begins to run by itself! And a starter going 40 MPH doesn't last long, and the whole motor died. So I had to push the truck into a sporting goods parking lot. Then it started to rain. I found out later that wires coming from my ignition lock cylinder were bare and they decided to touch each other.
Changing a starter... in a crowded parking lot... during a full out rain storm... priceless.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 04-15-2007, 10:13 PM   #19
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
Bled the rear brakes i just rebuilt on friday night. Also installed my green led's i bought from 70c10. Hey 1BadSS did you go to that swap meet in woodlandville, KS this weekend? Weather was crappy till 9:00 but after that there were a lot of good deals. Got a set of good used tires for my blue 72, a battery box, some of those inner fender clips, a glass pack, and a mallory tach and some other misc exhaust stuff to replace whats left of the one on the truck now. Sunday i figured out my ignition problem. After i converted the truck to HEI, it never has reved up properly. Turns out the spring loaded weights on the advance were frozen stiff and stuff was all out of wack. Oiled the advance setup, and replaced the springs/weights. After i reset the timing, she rev's with the best of them and purrs like a kitten.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 04-15-2007, 10:15 PM   #20
sick69
sick69's Avatar
very well could have been!!! it filled the whole rocker panel.
70 chevy lwb c10
Old 04-15-2007, 10:41 PM   #21
rage'nrat638
rage'nrat638's Avatar
installed the lifters, intake, set all the valves on my son's 400 i am giving him..
next prime., install the dizzy, carb, brackets and pulleys.
were going to start this one and make a video
installed a water neck and a intake few plugs on the vortec 355
waiting for some mounting brackets for the wire looms.
then i can go to town on this baby
rage'nrat638 is offline   Reply With Quote
Old 04-15-2007, 10:45 PM   #22
rage'nrat638
O YEA NICE WORK GUY'S
Old 04-15-2007, 10:51 PM   #23
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Yeah, had the 69 sitting out there for sale. Surprised no one bit on it for the price. OH well.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 04-15-2007, 11:02 PM   #24
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
724x4 I had to do the exact same thing to my HEI this weekend. The pins for the weights were rusted and the weights were stuck. I bought the MR Gasket weight and spring kit. Then I did a beautiful power slide with my new found power.
9.00 spring and weight kit = Double the horse power!
1967 K20 400TBI SM465/NP205
posi front, Detroit locker 4.56 rear
ND_guy is offline   Reply With Quote
Old 04-15-2007, 11:04 PM   #25
OlChev67
Ever heard of Beech Island??
OlChev67's Avatar
cool
Put in new distributor, plugs, wires, better timing made a new tool. deep fried a turkey
OlChev67 is offline   Reply With Quote
Thread Tools
Display Modes
