Old 04-16-2007, 01:56 AM   #1
wugunguy
70 C/10-Work in progress
wugunguy's Avatar
72 Door Panel Removal
This is probably a dumb question, but how do you get the interior door handles and window cranks off so you can remove the door panels?
thanks
In the garage
1999 Dodge Dakota Sport-Daily Driver
1972 Chevy K/5 CST AC/PS/PB/4x4/Tow Hooks/Tilt
1970 Chevy C/10-Current project
wugunguy is offline   Reply With Quote
Old 04-16-2007, 02:14 AM   #2
Aarons72s
Re: 72 Door Panel Removal
Go to the parts store and get a door handle clip removal tool. It looks like a flat piece of metal with a u shape in it. You slide the tool behind the handles to disengage the clip. Hope this helps.
Here is a drawing of the tool and how to use it.
Aarons72s is offline   Reply With Quote
Old 04-16-2007, 02:15 AM   #3
72CSTC5
72CSTC5's Avatar
There is a special tool that you can buy at just about any autoparts store that pushes a c-clip that is behind the window crank and door handle. Remove the two phillips screws out of the armrest and then the panels pulls off. It has door panel clips holding it in place.
72CSTC5 is offline   Reply With Quote
Old 04-16-2007, 03:57 AM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
^what they said^ just try not to shoot the clip across the yard or garage or across whereever you may be working on it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-16-2007, 06:31 AM   #5
brak
brak's Avatar
I have the tool and always found it cumbersome. a month or two ago sombody on here mentioned using a shop rag, and i've become a believer...
Press your panel in a little bit, instert the rag between the handle and the door panel, pull it around the handle, and the clip will pull right off.
After the first one, it makes perfect sense and you will have the other three removed in a matter of minutes.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-16-2007, 10:36 AM   #6
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: 72 Door Panel Removal
brak,
never thought of that one before, have to give it a shot. thanks
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 04-16-2007, 10:59 AM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Also, you don't have to purchase the tool. Roll the window down, push the panel in a little and you should be able to see "down into" the area where the clip is. (The reason you put the window down is so you don't hit your head on the glass ) You can then use a skinny screw driver that's perpendicular to the door panel to push the clip off. I've done this many times
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-16-2007, 11:45 AM   #8
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
yeah, you could go buy a tool, or you could get the stoutest wire coat hanger in your closet, cut out about an 8" piece, and make yourself a tool. push it behind the handle, rotate it to hook the clip and pull it off. The clip will stay with the handle, and your handles will come off.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-16-2007, 12:02 PM   #9
hootlube
And to reattach, put the clips back into the slot in the handle, they snap right back onto the door.
hootlube is offline   Reply With Quote
Old 04-16-2007, 01:48 PM   #10
wugunguy
wugunguy's Avatar
Sweet, thanks for the help everyone.
In the garage
Thread Tools
Display Modes
