Old 04-17-2007, 10:10 PM   #1
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Pics of my oddball lockouts 67 K-20
Here are the pics of the lockouts I've been having problems with, along with the spicer decal on the glovebox, and the option tag...does anyone know how to decode the options? maybe they might shed some light on this subject. I need to figure out what axle I have because the seal for the closed knuckle on the left is leaking and I'd like to replace it. Dad said anytime he ordered U-joints for it, he had to order 1 ton parts, but I was under the impression Chevrolet didn't make a 1 ton 4x4 in 67. I didn't scrape the grease off of it, but it has a 10 bolt cover and still has the differential tag, 4.55 gears in front. This truck is factory, nothing has been changed and to my knowlege, it hasn't been opened up since it was new, and Dad was the 2nd owner of it. It is factory equipped with Detroit lockers in both axles, and even has a decal behind the seat to explain that.
Anyone that knows anything about this animal, help would be appreciated.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-18-2007, 12:36 AM   #2
Big D
Big D's Avatar
Re: Pics of my oddball lockouts 67 K-20
I've got the same hubs on my 72 K-20 chassis. All I know about them is that they were made by spicer. Mine has a Dana 44 axle in the front, which have a 10 bolt cover. I know that Dana and Spicer are the same company. YOu might look on the Dana web site for info.
Heres a site for axle ID http://www.nationwideparts.com/differentials.htm
I disassembled mine recently, There a pretty simple design. I bead blasted mine, they work pretty good but are a little stiff to turn. I bet in the winter you would want to carry a pair of pliers to lock them in.
68 GMC
64 1/2 Mustang convert
A bachelor's life is no life for a single man."
- Samuel Goldwyn
Big D is offline   Reply With Quote
Old 04-18-2007, 09:43 AM   #3
O'l Buck
O'l Buck's Avatar
Dana 44 'eh? maye parts arent as imposible to find for these diffs as Dad has been leading me to believe. I think I'll take the hub apart again clean the grease off of it and try some gear oil. Good information to have on the site you posted, looks like the bolt pattern is the same on the 44 and the 60, 70, and 80....now I need to go scrape the grease off of the axle and check some numbers. Maybe I'll get lucky and it's got 60's
Thanks for the reply.
Chad
Old 04-18-2007, 11:00 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Those are the same hubs that are on my 69 K20 which has a closed knuckle Dana 44.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-18-2007, 12:33 PM   #5
1969K10
1969K10's Avatar
Originally Posted by O'l Buck View Post
Dana 44 'eh? maye parts arent as imposible to find for these diffs as Dad has been leading me to believe.Thanks for the reply.
I rebuilt my closed knuckle a couple years back. finding the gaskets that go around the "ball knuckle" were a PITA to find, but they are just felt. I actually screwed up and ordered 2 sets... so I've got an extra set at the house if you're interested.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-18-2007, 12:50 PM   #6
cobinder
Everything is work in progress
cobinder's Avatar
Buck I believe the pic and the ebay ad I posted will fit your axle. According to all the info I've found you should have this axle. They didn't use the corp 10 bolt until 77 or so, and it was never a closed knuckle.
You should be able to find the model "44" cast into the differantial. Also the production numbers are stamped on the main tube. If you look at the pic they would be right behind the tie rod and about 4" on to the long axle tube just out of the picture, warning they are very small 3/16's. Will also have the date of man.
Heres a link to the Dana site. Once you find the numbers you can go there and decode your axle.
http://www2.dana.com/expert/wc.dll?cvsp~Depdf~5~AXL~
Good luck!
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 04-18-2007, 01:07 PM   #7
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
Same as mine. I have to use a plier to turm mine occasionally. I have had them apart to clean them and reassembled using synthetic Mobil 1 grease. That did make a huge difference.
1967 K20 400TBI SM465/NP205
posi front, Detroit locker 4.56 rear
ND_guy is offline   Reply With Quote
Old 04-18-2007, 05:29 PM   #8
O'l Buck
O'l Buck's Avatar
Cool, I was starting to think dad was right and I had a rare bird that was impossible to find parts for. I found the productions numbers, but did not scrape the grease off of the differential case. The number were 1 18 7B5 602878 3 now that I've seen some more pics, and have some more information, the hubs posted from ebay look like they would work, same application, different style.
Chad
Old 04-18-2007, 09:08 PM   #9
O'l Buck
O'l Buck's Avatar
I got it figured out, dana 44 it is. I Found the spot to scrape and there it was, 44.
Thanks to everyone for the help.
Chad
Old 04-18-2007, 09:40 PM   #10
cobinder
cobinder's Avatar
Very cool Buck
Good luck!
04 Honda CRF "500"
Old 04-18-2007, 11:26 PM   #11
JAKES 68GMC
Aluminum slot wheels rule...
Same hubs here on my 68, I always need a wrench to lock them in.
JAKES 68GMC is offline   Reply With Quote
Old 04-19-2007, 01:49 PM   #12
OLDCHEV4X4
OLDCHEV4X4's Avatar
looks like 602878-3 is a 67 k20 standard diff. with 4:55 gears.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 04-19-2007, 01:54 PM   #13
1969 GMC
1969 GMC's Avatar
602878 3
This is the number you need, dana spicer calls it the bill of material number. According to my dana-spicer catalog, you have an axle from a 1967 K20 (duh!), open differential (your sticker just means you have a No-Spin in the rear, not front, unless your dad installed one), 4.55 gears.
Dang, OLDCHEV beat me to it!
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-25-2007, 08:17 PM   #14
O'l Buck
O'l Buck's Avatar
Thanks for all the great info, The gearing and the lockers have always been my favorite part of this truck, even with a worn out 350 with a burnt exhaust valve, it's still peppy and pulls good, great in the mud, and can do most anythig I ask it too....including getting my 93 K 2500 out of trouble when they are both buried to the axles in the wheat stubble
Chad
Old 04-27-2007, 01:53 AM   #15
Americanrider
I had the same hubs on my 67 K20, they where listed on the build sheet and glove box lable. I junked the axle and sold the hubs to board member Jerry Moss. I also had a Spicer Hubs factory pamplet that I sent along with them. Contact him and see if he still has it. He might make you a copy if you ask nice.
Americanrider is offline   Reply With Quote
Thread Tools
Display Modes
