04-20-2007, 01:41 PM | #1 |
Everything is work in progress
80 GMC K20 Hydroboost?
I'm wanting to convert my truck to hydroboost. Will my stock 80 pump work? Steering box? I've converted it to disc's in the rear so I know I need a new master cylinder setup. Was thinking I'd go to the boneyard and get the mc/hydroboost combo, but wasn't sure if I needed the pump and box also.
Thinking I'm gonna do a hydralic clutch while I'm at it any input would be very helpful.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
04-21-2007, 09:48 PM | #2 |
Re: 80 GMC K20 Hydroboost?
anybody?
04-21-2007, 09:56 PM | #3 |
Well, Whoop-dee-do!
No box difference. You can use your pump, but it will need an additional return port. Don't just put in a tee, drill a hole and weld in another port. It would be easier just to use the donor pump if it is correct for your brackets.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
04-22-2007, 04:42 PM | #4 |
Tool Addiction=Money Shortage
I used the pump off of the donor van because it has about twice the fluid capacity. The hydroboost has metric fittings and my steering box was standard thread so i had to change the pressure line from booster to half metric and standard. Overall it was an easy swap, and braking performance increased dramatically.
1967 K20 400TBI SM465/NP205 posi front, Detroit locker 4.56 rear |
04-22-2007, 07:18 PM | #5 |
Thanks a lot guys for the info. I'm off to the bone next weekend.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome Last edited by cobinder; 04-22-2007 at 07:18 PM. |
04-26-2007, 03:05 AM | #6 |
glamoros piece o' lowlife
I put hydroboost in my C10, but since I used an '80s diesel truck as a donor I ran into problems with the pressure lines - the ports in my steering box and pump required flared lines, while the donor lines were push-in and o-ring style. Cut the lines, flared, good to go. I used the stock nuts, but the donor ones would work too. Only thing is now my damn hydroboost is leaking around teh pedal rod upon release of brake pedal, are these units serviceable?
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
04-26-2007, 04:12 PM | #7 |
with either a 15/16" or 1" wrench, you couldve swapped the pressure line fitting in the back of the pump and saved the hassle.
05-03-2007, 12:04 AM | #8 | |
The Hose I had to change was from the Hydroboost to the steering box. The Hydroboost is metric and my steering box is standard flare. I could have gone with a newer metric psbox and wouldn't have had to modify anything, but my psbox is tight so I decided to keep it and just modify the hose. Nick
1967 K20 400TBI SM465/NP205 posi front, Detroit locker 4.56 rear Last edited by ND_guy; 05-03-2007 at 12:10 AM. |
05-03-2007, 10:55 AM | #9 |
What year and model trucks would I look for to pirate this system and a hyd. clutch from?
05-05-2007, 05:40 PM | #10 |
Anybody?
05-05-2007, 08:06 PM | #11 |
Well, Whoop-dee-do!
I think the hyd. clutch on a full size started in '86. Not sure on the hydraboost- maybe around '77. You can find it on HD 3/4 tons & 1 tons. All diesel Chevys & GMC's have it. Even diesel Blazers.
Thread Tools | |
Display Modes | |
