Old 04-22-2007, 02:14 AM   #1
Warren
Tail light wiring
I took the tail lights off last fall to put the rust proofing wands in and had read on the site where someone said he painted the metal part the bulbs sit in white and got brighter tail lights.
I want to sandblast epoxy primer and paint them white. The lower larger metal section with one bulb was easy to disconnect the wire off the back push twist and it comes off. The to psmaller piecs that is approx 2 x 2 with one bulb in it is different and cant figure out how that wire comes off or sort of looks like it doesnt. Prefet not to cut it and put a connector on dont want condensation in there.
Am I missing the point does the wire come free of that connector?? If so how.
Thanks,
Warren
Warren is offline   Reply With Quote
Old 04-22-2007, 02:37 AM   #2
wibilly
wibilly's Avatar
Re: Tail light wiring
there is a plug about 6"from the socket
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-22-2007, 08:24 AM   #3
70GMCer
70GMCer's Avatar
like wibilly said, and it can be a ***** to unplug.......pull on the plug, not the wire.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-22-2007, 09:05 AM   #4
Warren
Thanks,
Will go down under the truck as it is now there was not length of wire that I coulld pull through, the bottom yes it came well out from the truck and was easy to figure out. I was only able to pull it out from the truck maybe 2".
Makes sense will crawl under today,
Thanks,
Warren
Thread Tools
Display Modes
