Old 09-09-2002, 02:24 PM   #1
Custom 68
Custom 68's Avatar
removing light switch??
Hey guys I am going to remove my dash. I saw the wipers had a set screw to get the switch off but nothing on the light. Help!
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-09-2002, 02:26 PM   #2
bigvinnie
bigvinnie's Avatar
work your hand up behind the dash.... there's a button on top of the switch.... push it in and pull the knob, should come out with some patience...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 09-09-2002, 02:27 PM   #3
Jwill41
Jwill41's Avatar
There is a spring loaded pin on the switch. You have to reach up under the dash, find the pin on the switch, hold the pin in and the knob and shaft should pull out.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Thread Tools
Display Modes
