Old 04-25-2007, 01:52 AM   #1
DieselEater
DieselEater's Avatar
Headers?????????
I'm looking for some BBC headers that work with 4X4 67-72 trucks with manual clutch linkage.........Over the frame would work too if that's all that's available........Manufacturer and part numbers would be great! If you have a used set for sale that would be better. Don't mean to break the rules with that last sentence...........
Thanks,
A................
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 04-25-2007, 10:58 AM   #2
Burt4x4
Burt4x4's Avatar
Re: Headers?????????
Well I used Thorleys but I also converted to hydrolic clutch at the same time so I don't know if they will work for you. I use to run Hedmens on my SBC & manual linkage, nice fit..
Good LUck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-25-2007, 11:55 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
For my 69 K20 that I put a bbc into I used Dynomax Cermacoated headers, part number 86022, designed for the 67-87 BBC 2WD but also changed to a hydraulic clutch at the same time. As you can see from this pic, looks like there would be interference with the z-bar.
I tried a set of their 4wd bbc headers for the later years and had lots of other interference issues so they were not useable at all for me. Seems one side would go in but the other side couldn't even slide into place.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-25-2007, 11:31 PM   #4
DieselEater
Yeah, I traded for a set of long tube truck headers a while back and couldn't fit them between the frame and block. Also, the passenger side collecter was very close to the CV joint on the front shaft. Looks like over the frame is going to have to be the only option for headers. I heard there are some large primary Rams Horn VETTE manifolds out there that flow pretty good.....anybody know anything about them?
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 05-01-2007, 07:22 PM   #5
Ironhead
Ironhead's Avatar
DieselEater mentioned vette manifolds. I ran across an add in the 67-72 parts http://67-72chevytrucks.com/vboard/s...ette+manifolds
Ironhead Mike
'68 Panel 402BB
'84 Shortbox 4X4
'85 Blazer
'97 Silverado Ext. Cab
Ironhead is offline   Reply With Quote
Old 05-01-2007, 08:28 PM   #6
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Depending on what you are using the rig for headers aren’t worth the hassle for the small amount of HP they provide. I run stock manifolds on the stuff that I do not want to deal with burn wires, over heated starters and exhaust leaks on. I do have headers on my ’68 GMC with a bored and whored 396 but it has only seen less than 1 mile of driving in the last 7 years although it has actually gone more than 1600 miles on a trailer. No joke!
DirtyLarry is offline   Reply With Quote
Thread Tools
Display Modes
