Old 04-25-2007, 01:26 PM   #1
Rick Mills
Rick Mills's Avatar
Front Gear Change Question
I've got a '90 K-10 stepside.
When I bought it the 4" lift kit was already done. The lift was professionally installed by a company in Denver.
The previous owner didn't change the gears for the taller tires. It still has the original 3:42 in the rear and matching in the front so it has a lot of top end speed but it's really kind of a dog when I want to pull a trailer.
I've rebuilt Ford 9" race differentials, and am rebuilding a Mopar 8 3/4 differential right now.
Question...
With moderate mechanical ability, should I attempt to replace the front and rear gears in my 4X4 or take it to a shop? I've never been into the front axle of any 4X4.
Here are a couple pics.
The Fastor Pastor
'68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed:
'70 swb; TH-400 - bagged & shaved. Looking for new engine or parts.
Wife - Original {A Real Classic!}
Rick Mills is offline   Reply With Quote
Old 04-25-2007, 02:00 PM   #2
snj8198
snj8198's Avatar
Re: Front Gear Change Question
D-I-Y is a good way to learn. The 10bolt rear is easy. The front is more involved but there are plenty of how-to books and knowledgeable fellers on this site. Maybe get your hands on an exploded diagram with tech and specs of the front diff. Labor costs will be close to $400 or more for the front end alone. Roughly $200 for the rear. Do it yourself and you can spend that money on all new seals, bearings, etc if necessary plus you'll have the knowledge to fix it in the field if you break something.
Document it for the site's FAQ...with lot's of pics!!
Good Luck! -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 04-26-2007, 08:12 PM   #3
Rick Mills
Rick Mills's Avatar
I'm into saving money so.... Thanks for the vote of confidence.
The Fastor Pastor
Thread Tools
Display Modes
