Old 04-25-2007, 05:12 PM   #1
Imacarguytoo
Stripped Head
Guys i got a philips headed screw on my driver door card i cant get out. Ive tried taking a screwdriver and wackin it with a hammer and the driver just wont grab the screw. Anyone have any ideas?
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 04-25-2007, 05:28 PM   #2
72hotrod
72hotrod's Avatar
Re: Stripped Head
Are you familiar with opening a stuck jar lid with a table knife by striking the rim of the lid in the direction it turns to open? Get a regular screwdriver with a crisp edge and tap the screw on the edge driving couter-clockwise. Adjust the angle of attack to get the bite you need without knocking a chunk out of the screw. Work around the edge as you needed for a new bite at your screw because they are soft and will tear. Just work at it and apply some penetrating oil to help loosen it(PB Baster is real good).If you don't want to wait for original style screws to be ordered, just use 1/4-20 thread bolts.
72hotrod is offline   Reply With Quote
Old 04-25-2007, 07:11 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Stripped Head
what screw are you trying to get off?
Old 04-25-2007, 07:22 PM   #4
Shane
Shane's Avatar
Re: Stripped Head
drill the head off ... once you have the door panel removed, then you can get a grip on the remainder of the screw body with vise grips ... AFTER soaking it with Kroil or WD-40
good luck
Shane is offline   Reply With Quote
Old 04-25-2007, 07:25 PM   #5
Imacarguytoo
Re: Stripped Head
The screw thats holding the metal door card on
Old 04-25-2007, 08:15 PM   #6
Longhorn Man
Re: Stripped Head
I've drilled off a few of them. not fun.
If the door panel is junk, you can try vise grips to grab the head and twist it out.
Old 04-25-2007, 09:14 PM   #7
brak
brak's Avatar
Re: Stripped Head
thing that usually works for me...
use a die grinder or dremel to cut a groove, and use a flat head screwdriver to turn it out.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-25-2007, 09:28 PM   #8
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Re: Stripped Head
if the head isn't totally stripped yet, I've had some luck with an impact driver (the kind you put a screwdriver tip in and smack with a hammer).
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-25-2007, 09:40 PM   #9
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: Stripped Head
I do this alot.
I think Craftsman makes an impact drive style like O'l Buck mentioned, now that grabs on even when the screw head is badly stripped. Maybe worth checking out I heard about it somewhere and that it worked real well but, I have never yoused one myself yet. Good luck with it
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-25-2007, 11:01 PM   #10
70C10Toejam
Hellasick
70C10Toejam's Avatar
Re: Stripped Head
Had the same problem with one of mine...just drilled out the screw head and used a pliers or vise-grip from the backside after removing the panel.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Thread Tools
Display Modes
