Old 04-25-2007, 09:15 PM   #1
68_Step
I need horn help...
I took my horn assembly apart a couple months ago and promptly got side tracked. Today I go out to fix the horn and I can't remember how the pieces fit back together. Below I have a a picture of the 4 parts, I can figure out the horn button Can you tell me in which order that go back in? Also, the white ring has little "nibs" on one side, which way is up for that part?
Next time I will take notes, next time I will take notes, next time I will take notes...
67 Chev, C10, 3 on the column.
Thanks again!
68_Step is offline   Reply With Quote
Old 04-25-2007, 10:49 PM   #2
68 P.O.S.
Re: I need horn help...
I started a thread on this as well. This will help http://67-72chevytrucks.com/vboard/s...d.php?t=229041
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 04-25-2007, 10:54 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
The isolator ring goes first (top left) and the metal ring pictured below that goes on next. That ring is slightly convex in shape and the side that curves out shodl face the steering wheel. The last part are the pieces in the top right. Tighten the screws, install the cap and you should be ready to go.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-25-2007, 10:55 PM   #4
dave2953
dave2953's Avatar
That's funny. I had to refer to that thread to remember where the isolator ring went.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 04-26-2007, 09:08 AM   #5
68_Step
Dave2953 and 68POS, I will try this this evening. Thanks for the info and pointing me to the other horn thread!
Old 04-26-2007, 10:16 AM   #6
67CHIP72
STOLEN
67CHIP72's Avatar
Anybody know where to pick up an aftermarket isolator ring?
In Search Of
67CHIP72 is offline   Reply With Quote
Thread Tools
Display Modes
