Old 04-27-2007, 10:01 PM   #1
Geno
Geno's Avatar
Longhorn man...
IT's turbo 400, right. So would it being low prevent it from enguaging in any gears?
Geno is offline   Reply With Quote
Old 04-27-2007, 10:23 PM   #2
kwmech
Re: Longhorn man...
Low on oil, or a bad trans
Old 04-27-2007, 10:26 PM   #3
Geno
Geno's Avatar
Re: Longhorn man...
Low on trans fuild with a new torque converter and trans rebuild
Old 04-28-2007, 12:00 AM   #4
72armyswbtruck
72armyswbtruck's Avatar
Re: Longhorn man...
Silly question but did you use a can of copmressed air and clean out the tranny coolant lines?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-28-2007, 12:05 AM   #5
Re: Longhorn man...
Do you know how to send a private message?
Old 04-28-2007, 12:18 AM   #6
Geno
Geno's Avatar
Re: Longhorn man...
Hmm. Private message huh. Anyways, compressed air to blow out the lines. Why and when should you do that. Is that a maintence thing or just trouble shooting?
Old 04-28-2007, 01:28 AM   #7
kwmech
Re: Longhorn man...
You should always blow and clean out the trans lines when installing a new or rebuilt trans. This removes any potential debris that was left over from the previous transmision. This may be a silly question but was the convertor bolted to the flexplate? and how may quarts have you put in?
Old 04-28-2007, 07:25 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Longhorn man...
he had poured in 5 qts on a fresh rebuild... his dipstick is missing.
Yes, your tranny needs way more... I'm thinking a fresh 400 would need about 12 quarts.
And this would not only keep it from moving, but the more you try to move it, the more damage you'll do. You need to get a dipstick ASAP, then more fluid.
Old 04-28-2007, 07:37 AM   #9
Re: Longhorn man...
Not trying to offend.But,you started a thread addressed to a particular member and I wasn`t sure what you were asking by your wording.I figured it was something between you and him,as in part of a private conversation.You got your answer,that`s the main thing.
Edit:I thought you might be refering to alignment w/o the TH400 space at the rear mount or something.
Old 04-29-2007, 03:12 PM   #10
Geno
Geno's Avatar
Re: Longhorn man...
Yeh I know, no offence takin'. I'm buying a general application dipstick tomorrow since I still have the pieces I'll measure it properly.
P.S. I would like to thank all the members on this board for exchanging info back and forth. This is a great community and if you take a little...give a little.
Old 04-30-2007, 07:16 AM   #11
Re: Longhorn man...
BTW,got any better pictures of your truck?Your avater is a teaser.I didn`t even realize it was a`68 until your other thread about`68 CustomCampers.I`m a CustomCamperphile...among other things.
Thread Tools
Display Modes
