Old 05-04-2007, 03:33 PM   #1
hewlett2002000
hewlett2002000's Avatar
rear brakes are all fu**ed up!!!
brakes completely gone. hub was split in half. weeds and spiders all in it. ive never seen any this bad.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 05-04-2007, 09:02 PM   #2
hewlett2002000
Re: rear brakes are all fu**ed up!!!
excuse me, i ment drum. i took the other side off today. its a little bit better but not much. btw, i havent been driving it like that.
Respect:
Old 05-04-2007, 09:16 PM   #3
Uncle B
Guest
Posts: n/a
I had that happen on a 68 Mercury. The shoe had cut through the drum on the right front. I had no idea that it was that bad until it cut all the way through. Boy did it pull hard to the left.
Old 05-05-2007, 03:15 AM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
ive seen some really bad disc brakes but thats the worst drum ive ever seen
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-05-2007, 06:43 AM   #5
Woogeroo
Wow... the abuse.
I take it, that it has been sitting up for awhile?
-W
Woogeroo is offline   Reply With Quote
Old 05-05-2007, 11:17 AM   #6
hewlett2002000
yep. sitting for 3 to 5 years before i got it. it was an abandoned project.
Respect:
Old 05-05-2007, 05:52 PM   #7
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Are you going back with a different rearend? are just new drums?
gulfcoast66 is offline   Reply With Quote
Old 05-05-2007, 06:58 PM   #8
hewlett2002000
im not really sure yet. i got a rear end from a 84. im still thinking.
Respect:
Old 05-05-2007, 07:05 PM   #9
gulfcoast66
64-66 CHEVY JUNKIE
I got one comming off my truck here soon .
Old 05-05-2007, 08:34 PM   #10
hewlett2002000
do you know where i can find the gear ratio for my rearend? 1966 chevrolet C10. and also the gear ratio for my 62 chevrolet C10?
Respect:
Old 05-06-2007, 12:14 AM   #11
wild one
Registered.........
wild one's Avatar
The only way I know of to check gear ratios that is fool proof is to remove the rear differential cover and look on the ring gear for the tooth count stamp. It will say something like 41 11 (3.73) or 43 14 (3.08) etc.. You figure out the ratio by dividing the larger number by the stamped smaller number. Your trucks probably have 3.73,4.11,or 4.56 rear gears - depends on how they were optioned when ordered.
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 05-06-2007, 05:08 AM   #12
GREASEMONKEY72
thats the best way
-steven
Alte Seele S.S.
Old 05-06-2007, 12:08 PM   #13
hewlett2002000
thanks yall
Respect:
Old 05-28-2007, 07:20 AM   #14
hewlett2002000
ok yall, i got my rear brakes all back together. they were messed up bad, worse than they looked if thats possible. the PO took the rear passenger brake line off and put a nail in it and put it back on, must have been leaking. new drums, brakes, wheel cylinders, and springs. they work good now. sorry no pics but i worked on that damn thing from 7am to 3pm and i was so tired of messin with it i just wanted it done. trucks been sitting for 2 weeks and any time it sits it runs like crap for a little while.
Respect:
Old 05-28-2007, 09:59 AM   #15
Woogeroo
drum brakes can sometimes make ya require 4 hands, good job.
-W
Old 05-28-2007, 10:46 AM   #16
watahyahknow
watahyahknow's Avatar
seen a diskbrake that bad before (the center had broken out of it ) but this is a first for me
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Thread Tools
Display Modes
