Old 05-06-2007, 11:31 PM   #1
Luis_gz06
Luis_gz06's Avatar
Tilt steering column rubber seal removal
Whats the easiest way to replace the seals on factory tilt columns?
Would this be easier as shown on the 1st pic, removing the front shaft?
Dont wanna have to take the column apart up front just to replace those seals. Theres gotta be a easier to remove them (maybe). Thanks
Luis_gz06 is offline   Reply With Quote
Old 05-07-2007, 04:28 AM   #2
JimKshortstep4x4
Re: Tilt steering column rubber seal removal
The shaft will not come out unless you disassemble the column. I go through the trouble of taking the column apart to replace the rubber parts but I understand that the lower shift lever can be bent enough to replace them. Of course the lever has to be restraightened after replacement.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Thread Tools
Display Modes
