Old 05-08-2007, 10:00 PM   #1
johnyreb
Question Gmc 305e V6
Hi All,
This is my first post so please bear with me
I am looking to replace the carburetor and distributor. I have learned after lots of reading that the Pertronix Igniter Kit part #1162A and the Flame Thrower 40,000 Volt Coil part # 40001 would be a good choice. Would you all agree with this? Or is there something better? Easier? Cheaper?
For the carburetor I am considering the Holley Street 500cfm 2-barrel part # 4412S or the Demon Street Demon 2-Barrel Carburetor 500cfm part #1372210m. What do you think? Or is there something better? Easier? Cheaper?
The Stromberg-Bendix Model WW is badly worn and leaks, and I am tired of replacing points, is the reason for the change.
Thanks for any help and/or suggestions as to what I should do.
John
johnyreb is offline   Reply With Quote
Old 05-08-2007, 10:16 PM   #2
sb69chevy
sb69chevy's Avatar
Re: Gmc 305e V6
I don't know the answer to your question, but I'm sure someone will soon. Anyway, from Springfield, MO!!!
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 05-08-2007, 10:22 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
Re: Gmc 305e V6
I'm not too well versed with this motor, but I think you can upgrade to HEI. Someone please correct me if I'm wrong.
BTW to the board.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 05-08-2007, 11:08 PM   #4
1970bowtie
1970bowtie's Avatar
Re: Gmc 305e V6
from texas
Justin
1970 c/10 short wide bed
WTT 1970 chevy front end for 67/68 chevy front end
WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
1970bowtie is offline   Reply With Quote
Old 05-09-2007, 04:50 PM   #5
JAKES 68GMC
Aluminum slot wheels rule...
Re: Gmc 305e V6
I guess I'll take a crack at this one........
Put the Holley 500 2bbl. on your V6. You will be amazed how much it wakes them up. They won't be any street machine or tire smoker, but it will give it a lot more power and more giddyup. I can't help you as far as the distributor goes. You can convert to HEI by using a Buick 231 distributor, but it requires a little work. You can find more info about the swap and V6's in general at www.6066gmcguy.org. Hope this helps.
Jake
JAKES 68GMC is offline   Reply With Quote
Old 05-10-2007, 03:36 AM   #6
rwgregory
Re: Gmc 305e V6
Welcome from SoCal. As for your ignition the Pertronix setup would be the cheapest and easiest. A better setup would be to swap in an HEI setup from a '79 thru '85 Buick 3.8 even fire V-6. However that would require some minor machine work and a new set of high quality wires. The Holley 2 barrel would help much, and it's fairly easy to do. Also, if you hav'nt done so already split the exhaust to duals with some free flowing mufflers and ditch the single pea-shooter exhaust system.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 05-10-2007, 03:38 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Gmc 305e V6
youve got some good info so far so ill just say, WELCOME TO THE BOARD
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-11-2007, 08:29 PM   #8
johnyreb
Re: Gmc 305e V6
Thanks for all the good info.
One more question though, which would you all get, the shiny zinc-coated finish Holley or the Dichromate finish?
Does the shiny zinc-coated finish hold up ok?
Thanks again for all the info.
John
1967 GMC
Longbed
305E V6
3 on the tree
Old 05-11-2007, 08:35 PM   #9
JAKES 68GMC
Re: Gmc 305e V6
I've got the shiny one, the air cleaner covers it up pretty well and you can't see it much. But its been on for over a year now and still looks pretty good. If I wiped it off once in awhile it would look real good.
Anymore questions you have, ask away. We can answer them.
Thread Tools
Display Modes
