Old 05-09-2007, 09:39 AM   #1
72longbed
72longbed's Avatar
Question Is This Normal (np205?)
For all you guys out there that know your way around an NP205 transfer case, is it normal for them to push out a lot of gear oil thru the speedo cable drive? Is there a seal or gasket inside this area that would stop the flow?
Need to do something quick.
Thanks,
72longbed
72longbed is offline   Reply With Quote
Old 05-09-2007, 10:16 AM   #2
snj8198
snj8198's Avatar
Re: Is This Normal (np205?)
sounds like either the plastic speedo gear has worn out, maybe has a groove worn into it, or the small lip seal around the speedo gear is shot. When either of these happen the speedo cable acts like an auger and pushes the oil up the cable. maybe time to replace the assembly.
good luck -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 05-09-2007, 11:31 AM   #3
72longbed
72longbed's Avatar
Question Re: Is This Normal (np205?)
Steve, is the speedo drive assembly available from anywhere new? OR maybe somebody out there has a used one (for a Chevy NP205) that doesn't leak and they want to part with it?
Thanks Steve,
72longbed
Old 05-09-2007, 11:52 AM   #4
snj8198
snj8198's Avatar
Contact Performance Automotive and Transmission Center http://www.transmissioncenter.net/ 888-877-1008
good luck! -steve
Steve
Thread Tools
Display Modes
