05-09-2007, 05:25 PM | #1 |
Tow Dolly
Has anyone ever towed a 1/2 ton LWB with a U-Haul tow dolly?
We should hopefully be bringing my sons truck from the painters to home to put it back together this weekend! WOO HOO FINALLY! It has no lights,bumpers,glass or anything to make it legal to drive. I dont really want to call U-Haul because when I called them about a trailer to take to the painter, they told me they could not rent me a trailer to tow a 1/2 pickup even though it was just a cab & box on the chassis,no motor,doors,front sheet metal,NOTHING!
Great minds think alike,So do ours |
05-09-2007, 05:49 PM | #2 |
Re: Tow Dolly
I ran into the same problem. Tell them you are towing a ford escort or something small of that sort. The only problem is, that if there dolly falls apart they wont be liable for damages even though it is there junk dollies fault. I am not saying there dollies are junk. But there could always be some hidden crack or defect somewhere.
05-09-2007, 06:24 PM | #3 |
Re: Tow Dolly
You can get one of those tow hitches that attach to your trailer ball and to your sons front bumper ,or frame. You should be able to get one for around 75 dollars that about what you would pay for the rental.
05-09-2007, 08:15 PM | #4 |
Re: Tow Dolly
I rented a U-Haul tow dolley once and had to take it back, it was too narrow. I luckily found a guy near where I was picking up the short stepside that had an older tow dolley for sale. Otherwise I would have had to rent the U-Haul car hauler. And like he said you need to tell them you are hauling something else. When I first tried to make the reservation online and said I was pulling a 68 Short Stepside with a Dodge Caravan, they wouldn't rent the tow dolley until I said it was an Escort.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
05-09-2007, 08:31 PM | #5 |
Crew Cut
Re: Tow Dolly
hart rod out of pensacola fl came to my place this past weekend with what looked like a u haul dolly and picked up a 1/2 ton chev p/u with no problem
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
05-09-2007, 09:29 PM | #6 |
Re: Tow Dolly
I pulled a 1/2 T SWB from Joes this weekend, no problems what so ever. A couple of months ago, I pulled the My 67 LWB Crewcab from Junction, TX to Pensacola, FL (867 miles) with a u-haul tow dolley. I told them I was pulling a 1/2 T truck, . It pulled great.
PS My buddy pulled the Crewcab from Phoenix, AZ to Junction, TX with his V8 F@#$ Explorer. He had to drive a little bit slower than I did pulling it with my 03 Suburban, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-10-2007, 08:35 AM | #7 |
Re: Tow Dolly
As a U -haul dealer myself, i had to respond, the reason u haul does not allow use of the tow dolly is because of safety issues, if you are pulling a 4000 lb truck with a vehicle that weighs 3000 the lead vehicle is in danger if he has to make a sudden stop,remember forward enertia is gonna try and put your truck in your backseat! As far as F@&d Explorers are concerned it seems after the rollover problem,uhaul doesnt allow any trailers or tow equipment to be pulled by one! you are right if you have a wreck pulling an unauthorized vehicle insurance is cancelled! So for about 10 bucks more go ahead and get the transport,its much safer and really easier to pull!
05-10-2007, 09:25 AM | #8 |
Re: Tow Dolly
I havent used the dolly but ive used the auto transport twice with good results, once on a SWB '70 and once on a '73 Blazer. The only thing you want to be careful about is the tires. A 4x4 will not fit due to the wheel/tire width and the same is true for anything wider than a stock steelie so get yourself a set of those if you plan on using the transport.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
05-10-2007, 11:35 AM | #9 |
K5Camper
Re: Tow Dolly
I've towed a lot of small cars with an old uhaul dolly. One point you have to watch is to make sure the straps over the front tires are secure. If they are loose the truck could fall off or jump forward and get wedged onto the dolly with the wheels in front of where they are supposed to be and the rocker panels laying on the ramps.
I never had it happen while towing myself, one of my nieghbors was bringing a 67 mustang home and hit the railroad tracks less than a mile from the house. The mustang jumped forward and was stuck on the dolly. It took 3 floor jacks and a ton of grunt to get the car off the dolly without causing more damage. Just take it easy and make sure the straps are tight and check them on the way.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
05-10-2007, 08:53 PM | #10 |
Sisyphus was my mentor!
Re: Tow Dolly
I'm all about the towbars that bolt to the front end of the truck to-be-towed. When I (saddly) had to store my two 67's to go off into training, I towed one with the other 175 miles at 50mph. You can feel that extra truck wanting to push the towing truck around but if you are safe & not in a rush, its a good option. It was slow stopping & starting but the towbar with the safety chains is imo the safest & easiest way to tow. The bars are cheap & you can hook the wiring into the towed vehicle. With these rental hassles & the fact that they often dont fit our trucks, I cant see why everybody isnt using towbars on our trucks.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
05-10-2007, 09:13 PM | #11 |
its all about the +6 inches
Re: Tow Dolly
tow bars all the way here.
I have thousands of miles logged with tow bars, and other than towing a truck that should have been loaded up on a trailer (front wheels locked straight forward) I have never had a single issue with the tow bars... even whenthe towed vehicle outweighed the tow vehicle. |
05-11-2007, 12:30 AM | #12 |
Junior Member
Re: Tow Dolly
I towed my 72 LWB 2WD home 300 miles on a Uhaul transport. It was a tight fit getting it on there, the wheels rubbed, so make sure you can drive it on and off (or find skinny tires as suggested above). Here's a link to my photo gallery when I got it home..
http://thequicks.smugmug.com/gallery/2679207#141832160 |
05-12-2007, 12:07 PM | #13 |
Re: Tow Dolly
1100miles, one way. make sure the tow dolly is wide enough , mine is homemade and heavy duty. make sure those adjustable straps arnt adjusting while your driven. my straps have started slipping on me im looking into better straps soon take it slow and check the straps often especialy if your inexperanced.
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) Last edited by jc; 05-12-2007 at 12:07 PM. |
05-12-2007, 04:08 PM | #14 |
Jamie Hyneman is my twin
Re: Tow Dolly
I'm getting ready to do this same thing. Here is what I'm looking at
Checker Auto's tow bar What do you all think? for $125
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
05-12-2007, 05:21 PM | #15 |
Re: Tow Dolly
I got something similar at TSC. I also recommend the mag-base trailer lights. You hook them into the trailer harness and you're guaranteed to have lights on the other end of the towed vehicle.
My 0.02 Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
05-12-2007, 05:25 PM | #16 |
Re: Tow Dolly
that tow bar looks fine. remove the front bumper, and bolt it directly to the frame. No bumper damage that way.
I don't like the magnetic lights, I made a harness that goes from the trailer plug on the tow vehicle, to the tail light harness on the towed vehicle. you don't need power or anything on the towed, just a good harness and good bulbs/grounds in back. |
Thread Tools | |
Display Modes | |
