Old 05-09-2007, 05:42 PM   #1
timzrides
timzrides's Avatar
Seats In A 48-54
Just like the title, what aftermarket or junk yard seat and from which vehicle would fit best or pretty good in my 48-54. Would prefer Bench?
thanks
timzrides is offline   Reply With Quote
Old 05-09-2007, 08:41 PM   #2
pgf545
pgf545's Avatar
Re: Seats In A 48-54
Tim, I probably can't help you much but we got a set of sets out of a Explorer, but I am not sure how they are going to fit. Hopefully in the next few weeks I can give them a test fit. The only reason we got them is they were from a friend that was wanting to get rid of them. But they are buckets and I am thinking they are too tall and will stick up in the window... hope this helps.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 05-09-2007, 09:10 PM   #3
solidaxel
solidaxel's Avatar
Why do you not want to use the stock bench seat?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-09-2007, 09:12 PM   #4
cajundragger
I cut 6" out the middle of a 67-72 bench and it fits perfect
cajundragger is offline   Reply With Quote
Old 05-09-2007, 10:09 PM   #5
timzrides
timzrides's Avatar
solidaxel, i don't have one, that would be my first choice, but i need to find something to continue with the steering and its placement
Old 05-09-2007, 10:49 PM   #6
Hart_Rod
Hart_Rod's Avatar
I used the seats out of a late model Chevy pickup (98 and up) and a center console out of a dodge dakota.
Hart_Rod is offline   Reply With Quote
Old 05-10-2007, 02:46 AM   #7
Daniel U
Daniel U's Avatar
I got mine through http://www.glideengineering.com/
seen here in the pic without the foam or leather wrapping.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 05-10-2007, 12:51 PM   #8
2ndGenRR
2ndGenRR's Avatar
Daniel U - I have been looking at the Glide Engineering seat. Did you use a stock floor pan? Did you make the brackets? I need to replace the floor pan and wanted to use *****in' stuff, but don't know how the 'glide seat will work with a flat floor pan. Thanks.
The Stable:
1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me.
1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck.
1951 Chevy 1/2 ton, 3-window...building to sell.
Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado.
I grew up in Flint, Michigan so I can't help but to bleed Chevy!
2ndGenRR is offline   Reply With Quote
Old 05-14-2007, 01:12 AM   #9
Daniel U
Daniel U's Avatar
Paul pulled the factory seat foundation (ground off the spotwelds)and built custom brakets that allow for a comfortable angle for long cruises. If you choose "glide" you 'll have to build/buy your own brakets. Then you can replace your floors without any worries.
Old 05-14-2007, 08:16 AM   #10
2ndGenRR
2ndGenRR's Avatar
cool. thanks for the info.
The Stable:
Old 05-16-2007, 09:50 PM   #11
bobj
I used a bench out of a Dodge Dakota -- It fits the width of the truck very well. Look at the pics under " My 48 I just finished" - Bob
bobj is offline   Reply With Quote
Thread Tools
Display Modes
