Old 05-14-2007, 01:54 PM   #1
OhNoJoe
OhNoJoe's Avatar
Harmonic Balancer Puller & Installer Set
I pulled my 292. Now it's time to strip the tin. I have a pully puller that hooks around and pulls on the sides. I heard that I shouldn't use this type but rather it is better to use a puller that treads into the HB itself. Like this one.
http://www.mytoolstore.com/wilmar/wtech06.html
W89711 $73.75
For removal and installation of harmonic balancers on most automotive and light truck applications
Master set: includes necessary bolts and adapters for most applications
Bilingual instructions
Replacement Part Availability
However it is a little high priced. The one at Sears (sold out) is like 25-30 bucks, Do I get a 50 buck advantage but getting the one listed above?
OhNoJoe is offline   Reply With Quote
Old 05-14-2007, 02:01 PM   #2
nvrforgotten52
nvrforgotten52's Avatar
Re: Harmonic Balancer Puller & Installer Set
autozone will let you borrow one...
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 05-14-2007, 02:20 PM   #3
cdowns
cdowns's Avatar
that's about the same one i have a quality tool in my opinion is well worth the money// as far as the free tool programs at the chain stores if you add the time and expence running to pickup and dropoff as well as the fact that if you have an immediate need for one sometime at midnight well you're not saving a thing over the 30+year lifespan of the tool
Old 05-14-2007, 11:40 PM   #4
OhNoJoe
OhNoJoe's Avatar
After reading the posts about the problems folks can run into hammering on the HB I'm thinking it's worth the $. Hopefully, I'll still be goofing around with this stuff in 30 years or when I'm 80
Thread Tools
Display Modes
